Author Topic: Rom separation in MA  (Read 7483 times)
yardos1225
  • Last login:November 22, 2010, 07:17:05 am
« on: August 23, 2010, 07:29:24 pm »
Hello all, a quick question. I am wondering how to get different versions of a rom to appear in Maximus. Let's say for example; I have the Mortal Kombat 3 rom. In Mame32 it shows up as MK3 but subtitled I can play Ultimate Mortal Kombat 3 like their different versions stemming from the one rom file. In Maximus it would appear only as mk3 but I prefer ultimate and was wondering how to make that version available without having to do so for all the other games???
Bender
Re: Rom separation in MA
« Reply #1 on: August 23, 2010, 11:41:33 pm »
so you have clones turned of in MA?
I think you could manually edit that list file after MA creates it, but 'm just guessing
yardos1225
« Reply #2 on: August 24, 2010, 12:09:03 am »
Yeah I've had to turn clones off to get rid off all the other riff raff. Trying to find a way to turn just the Mk3 clones back on...?
jimmy2x2x
« Reply #3 on: August 24, 2010, 11:33:01 am »
I just changed my settings to allow clones to be displayed, rescanned.
Then added 2 versions of Galaga to my favourites.
Disabled clones, rescanned.
Now I have no clones in my games list, but both versions of Galaga in my favourites.
Is this what you want to do with MK?
  • Last login:August 24, 2025, 09:08:53 am
« Reply #4 on: August 24, 2010, 11:36:11 am »
Hmm - favourites, eh?  I don't think I've seen that setting.  Gotta look into that myself!
deepblue
  • Last login:December 12, 2018, 07:39:28 pm
  • Billy vs. Steve
« Reply #5 on: August 24, 2010, 03:20:47 pm »
I'm pretty sure you could edit the MAME.lst in the preferences directory (which is the master listing) and add it in? Not sure if the file format is proprietary though.
jimmy2x2x
« Reply #6 on: August 26, 2010, 06:39:21 am »
That should work, but you will lose it when you upgrade to a new version of mame.  If you put your games in a favourites list then they will stick, regardless of updating.
« Reply #7 on: August 26, 2010, 08:36:11 am »
I opened it in a notepad-styled reader last night, and it looks like the ".LST" files are proprietary.
This.
I played with that last night, and used "Import" to bring in everything from my "MAME.LST" file into my Favourites, and then started to manually pare them down.  It looks like a daunting task, so I'm hoping someone else might have a better idea.
deepblue
  • Billy vs. Steve
« Reply #8 on: August 26, 2010, 09:53:26 am »
It likely won't open correctly in Notepad - try Editplus or another more robust text editor.
« Reply #9 on: August 26, 2010, 10:15:05 am »
I didn't use Notepad, I mentioned I used a notepad-styled reader. - I used Notepad++, which is robust, and showed too much back-code in the file.
jimmy2x2x
« Reply #10 on: August 26, 2010, 10:28:10 am »
What are you trying achieve with your favourites list?
Are you saying you have imported EVERYTHING into your favourites, then stripping it down?
« Reply #11 on: August 26, 2010, 10:30:04 am »
What are you trying achieve with your favourites list? Are you saying you have imported EVERYTHING into your favourites, then stripping it down?
I'm trying to get my own "top 100" or so in there.  If there's a better way to do it, I'm open to it.
deepblue
  • Billy vs. Steve
« Reply #12 on: August 26, 2010, 10:33:30 am »
You could always do it using the multiple mame version approach - that is, take an emulator scheme in MA that you won't use (e.g. RAINE) and make a custom directory of Mame games you want in your top 100.
Follow the approach described here: http://forum.arcadecontrols.com/index.php?topic=100463.0 and it should work.
jimmy2x2x
« Reply #13 on: August 26, 2010, 10:35:54 am »
I set aside some time to work on my favourites, it starts off empty.
1) show clones in main game list
2) start at the top of the list and work through the games, maybe doing one letter per session: IE Im going to to the 'A' games tonight - maybe add 10 games to your faves, then switch to the faves list and whittle it down to the essentials that fit your criteria - give yourself sometime to play each of the games a little and make an informed choice on what you like to play today, not what you liked to play 25 years ago.
3) rinse repeat
4) once complete, prune the gamelist or add new games as you discover/remember them
If you think about it, with over 8000 games (inc clones) its a much less daunting task to add 100 from nothing, rather than delete 7900 from 8000.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #14 on: August 26, 2010, 02:04:02 pm »
The way I did it was to import the entire main game list after I scanned MAME to a Favorites list.  Then I removed the roms that were dupes or garbage.  I also checked the option to remove adult roms in my main list before I copied it.  The result is a perfect list, which includes clones that I choose.  For example UMK3 and the Challenger version of MKII.
I'd be happy to share the .lst file for those that are interested.  It's a proprietary format that only MA understands so cannot be edited outside of MA.  I am running version 2.10 of MA but it should be compatible with earlier versions as well.  I am running MAME .119 but that shouldn't matter either.  You can always add games from your main scanned list.
The only caveat, is that the game lists are location specific, which means that you must have mame in the C:\mame folder for my list to work for you.
EDIT:  Gamelists attached below.  I included MAME Favorites, MAME Multiplayer (great for quad panels like mine - these are games that have 3 or more players), MAME Shmups and MAME Sports
DeLuSioNaL29
« Last Edit: August 27, 2010, 10:49:33 pm by DeLuSioNal29 »
