Author Topic: New here and need some Help  (Read 743 times)
yweiss
  • Last login:October 04, 2012, 03:34:31 pm
« on: August 19, 2010, 03:42:33 am »
Hello, I'm new in this thing called Mame, I saw a many posts and I want to build a Jukebox Button only, I want to do a layout for my button and then put it on my CP and drill the holes but I dont know how to do the layout in real size of the holes (28 mm) so I hope you can help me, another thing is I wnat to use SKjukebox and I wanted to know if it  is good software for button only jukebox and if you can tell me where to find some photos of button only jukebox, I found some in the other forums (mp3\jukebox) but if you can tell me where to find more.
thanks guys!
mgb
  • North East, US
Re: New here and need some Help
« Reply #1 on: August 19, 2010, 01:42:48 pm »
Its setting up the dpi (dots per inch) setting in the art program you are using.
for instance if you're using 300dpi  and you draw a line that is 300 pixels, and you then print it to1:1 scale, your printed line will be one inch.
What program do you plan to use?
There are also good templates online.
This site has some good arcade templates http://www.slagcoin.com/joystick/layout.html
remember there is a forum catagory here for skjukebox
good luck
yweiss
« Reply #2 on: August 19, 2010, 03:18:33 pm »
I want to use photoshop, the button i'm gonna use is standart pushbutton from ultimarc.com so the holes is 28 mm, how do i do in photoshop a circule diameter 28 mm ? I saw the templats in the link you gave me, there is a way to use this but to add some more holes?
