Author Topic: t-molding, wood, and lexan size?  (Read 1715 times)
transfan
  • Last login:April 07, 2011, 11:38:37 am
« on: August 09, 2010, 02:21:11 pm »
Hi everyone,
I'm building a CP in the U.S. and I have to purchase the wood, molding, and LEXAN.
Since I have a choice, which size should I get of each?  On arcadeemulator.net they sell different size t-molding for 5/8" wood or 3/4" does that mean it will fit 3/4" wood or wood + lexan = 3/4"?
I plan to use mdf
lilshawn
  • Last login:December 15, 2025, 02:24:06 pm
Re: t-molding, wood, and lexan size?
« Reply #1 on: August 09, 2010, 02:34:12 pm »
no lexan is extra thickness. 5/8" is a little thin for my liking. 3/4 is better.
i just bevel the edge of the plastic i'm using for the overlay. helps soften the edge.
buy 3/4" wood and 3/4" t-moulding.
Franco B
« Reply #2 on: August 09, 2010, 02:44:16 pm »
Do not use polycarbonate (Lexan) to cover your control panel, use Acrylic (Plexiglass etc).
I think I need to change my sig^^  :)
lilshawn
« Reply #3 on: August 09, 2010, 02:46:01 pm »
yeah, lexan although nearly indestructible, scratches like hell.
plexi is a little tougher (in that respect)
transfan
« Reply #4 on: August 09, 2010, 02:51:50 pm »
I thought that the width of the wood + plastic = t-moulding.  Doesn't the t-moulding cover the plexi?
« Reply #5 on: August 09, 2010, 03:35:35 pm »
No.  I mean, 3/4" plywood isn't actually 3/4" but 3/4" MDF is but either way, wood/MDF + lexan/plexiglass ≠ 3/4".
You should offset the slot for the t-molding (to cover the lexan/plexiglass) and then bevel the bottom of the MDF/wood panel.  No one will be able to tell.
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #6 on: August 09, 2010, 04:22:28 pm »
A visual to elaborate.
