Author Topic: Best way to drill holes in plexi  (Read 5867 times)
Mikezilla
« on: August 09, 2010, 01:54:42 pm »
Sup guys. Finally got my dynamo CP together, I just need a new piece of plexi glass to cover the overlay. Whats the best way to drill the holes out of the plexi without breaking it? Just get a 1 1/8 spade and just go to town? This noob will greatly appreciate any advice! Thanks!
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
Re: Best way to drill holes in plexi
« Reply #1 on: August 09, 2010, 02:14:55 pm »
Although others will insist a forstner bit or hole saw is the way to go, a spade bit is fine - just use high speed, LOW feed.
If you have a router, you can use a pattern bit and your cp as template, just clamp plexi to cp and drill 'small' starter holes to fit the pattern bit into and go to town.
« Last Edit: August 09, 2010, 02:26:37 pm by EwJ »
jholman76
« Reply #2 on: August 09, 2010, 02:56:42 pm »
I would second using a router. I used a top-mount bearing flush-trim bit for my CP on my bartop. I clamped the plexi to the CP with the holes drilled and slowly lowered it down. the bit punched through and then I just routered in the hole with the bearing.
on my upright CP we used a forstner bit. every hole we did made me more and more nervous but they all came out ok.
just make sure the speed is HIGH!
joe
Mikezilla
« Reply #3 on: August 09, 2010, 03:03:42 pm »
Thanks for the input guys! Im gonna go to home depot tonight and buy what I need, hopefully if the GF is in a good mood, I can do it tonight, if not Ill have to wait.  ;D I really appreciate it. Ill let you guys know how it goes!  :cheers:
MikeyMerse
  • Last login:September 30, 2011, 03:39:52 pm
« Reply #4 on: August 09, 2010, 05:05:09 pm »
Let me know how the spade bit works out for you, I think I will be going with this option.
Mikezilla
« Reply #5 on: August 09, 2010, 05:21:29 pm »
No problem. Ill keep ya posted. Hopefully it works, seems to be the cheapest option.
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #6 on: August 10, 2010, 01:52:11 am »
Best to put some scrap wood under the plexi - this helps avoid breakage.
I don't think high speed is the way to go - it tends to melt at high speeds.
Edit: Some good advice here: http://forum.arcadecontrols.com/index.php?topic=24091.0
« Last Edit: August 10, 2010, 01:54:56 am by DrumAnBass »
"Some drink from the fountain of knowledge; I only gargle."
Mikezilla
« Reply #7 on: August 10, 2010, 01:24:38 pm »
Thanks for the advice drumnbass. Thats very informative. I appreciate it! Im gonna try to get to it this weekend. Pretty busy during the week. Work, GF, bunch of other stuff... Ugh. I just want to work on my arcade dammit!!!  :laugh:
Mr. Greenjeans
  • Last login:July 10, 2013, 03:51:51 pm
« Reply #8 on: August 13, 2010, 05:27:10 pm »
+1 forstner bit & scrap wood underneath
Mikezilla
« Reply #9 on: August 16, 2010, 12:22:12 pm »
Didnt have time to do it this weekend. Went to the Horseraces and saw a horse get shot. Was crazy. The GF bet on her too lol. Anyway, going to home depot tonight, so Ill make a post tomorrow to let you know how I did. Thanks to everyone for the tips.  :cheers:
« Reply #10 on: August 17, 2010, 09:36:09 am »
i used a dremel.
Mikezilla
« Reply #11 on: August 17, 2010, 12:10:21 pm »
I need to invest in one of those. In case anyone was wondering, Lowes is completely inferior to Home Depot. They didnt have any of the bits I needed, or the sheets of plexi/lexan. Garbage. My Home Depot caught fire and they are rebuilding it, tried Lowes. Garbage. Now everything has to wait until I order it, or until Lowes gets a shipment in...    :hissy:
rohan
  • Last login:December 30, 2011, 08:24:04 pm
  • I'm a winner.
« Reply #12 on: August 25, 2010, 04:40:29 pm »
Stepper bits are amazing!  They come in many different sizes/shapes and you won't get any cracking or crazing when you drill...It's perfect for drilling button holes.
Dave & Buster's uses this method on their games and I used it on my MAME machine with great success.
It doesn't matter if you win or lose....it's how you play the videogame.
Mikezilla
« Reply #13 on: August 25, 2010, 05:11:26 pm »
Thank you for the pics! Arent those types of bits really expensive? I suppose I would justify the purchase by future cabinet construction, but I think I remember seeing those for 50 bucks... Am I wrong? Hopefully I am..  :dunno
rohan
  • I'm a winner.
« Reply #14 on: August 25, 2010, 09:19:19 pm »
They are expensive, but they do work...Buying a single good stepper bit that goes to at least 1 1/8" is expensive, but I've seen deals where you can get a whole set for about the same price as that one big bit.  I borrow mine from work (Dave & Buster's) but the occasional deal can be had at Lowe's.
Mikezilla
« Reply #15 on: August 26, 2010, 11:37:37 am »
Cool thanks for the tip. Ill have to check Lowes again, was just there the other day and they didnt have ---steaming pile of meadow muffin---. Was kind of irritated cause I have no place else to go, the nearest home depot is under construction after a fire, and the closest one aside from that is 30 mins away. Im just lazy  :lol
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #16 on: August 26, 2010, 08:31:57 pm »
Here's how I did it with some pictures to show:
I clamped my 1/8" plexi over my control panel with the holes already drilled in the wood. I did the cut to size of the outside edges with a router and a flush trim bit.  The bit cut threw the plexi just like a knife through warm butter.  Basically felt like I was melting it to the right size.  Really quick through and an easy cut.
For the button holes, I went really slow, especially working with a forstner bit which I thought was probably not the correct bit for plexi.  Something with a much sharper point I think would have worked better.  Sharper and a very steep profile.
Some cuts were a bit too close together, and I was worried about getting a crack between the two spots.  So I started putting the buttons in to help hold down the plexi and keep the work supported.
If I pressed a bit too hard while drilling and tried to go a bit too quickly, I did get cracks inside the area that was being drilled out.  Luckily, I think I got through the whole thing without causing it to shatter.  Like the others guys said, I think the trick is high speed with the drill, very slow speed through the material.
Finished holes:
Seperate peices, good view of joystick and trackball cuts here:
When drilling holes for the joysticks and trackball opening I moved the plexi around and used the button holes for better support.  If I had done it where the joysticks openings were, it would have been a disaster.
The trackball starter hole, and center joystick behind it (where the 4 way stick will go):
I used the trackball mount as a template for the router to make the hole the correct size.  The metal here is maybe a 1/16th of an inch.  I was extremely careful that I lined up the flush trim bit at the exact right depth to make sure the bearing made contact with the metal.
Finished up:
Here's the peices seperated but now with the final holes cut.
« Last Edit: May 21, 2014, 03:10:03 pm by bratwurst »
Mikezilla
« Reply #17 on: August 27, 2010, 03:17:26 pm »
Holy ---steaming pile of meadow muffin--- bratwurst, thanks so much for the time and the pics! Looks awesome.  :applaud: Im bummed, I keep saying Im going to do it, and I keep running out of time thanks to my GF and having to take my dog to the vet etc...Ugh. I just want to work on my arcade damn it!  :hissy:
Thanks again for the great post.   ;D
