Author Topic: Newer game resolutions  (Read 1966 times)
DirtyDachshunds
    • First Project: MillerCade
« on: August 09, 2010, 12:19:29 pm »
Is there anyway to get newer cab friendly games (ie Lego Harry Potter) down to 640x480 (in my case) if the game doesn't support it?  Currently the lowest resolution the Lego Harry Potter supports is 800x600.  I bought the game for my arcade cabinet and I would like to play it on my cab.
Cheers  :cheers:
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Newer game resolutions
« Reply #1 on: August 09, 2010, 01:17:42 pm »
It's probably going to be different per every game you want to do.
Looks like there is a "pcconfig.txt located in appdata in roaming for windows 7" that is the game configuration data.
Should look something like this:
Code: [Select]
FileVersion 3
ScreenWidth 1024
ScreenHeight 768
WindowWidth 1016
WindowHeight 697
WindowLeft 0
WindowTop 0
ScreenRefreshRate 60
VerticalSync 0
FSAA 0
AspectRatio 0
TextureQuality 0
SoftParticles 0
ForceMultithreadedD3D 0
IgnoreVendorPresets 0
Brightness 10.000000
SFXVolume 10
MusicVolume 10
MasterVolume 4
MusicEnabled 1
MouseSensitivity 10
InvertY 0
Vibration 0
BloomEnabled 0
ExposureControlEnabled 0
DoFEnabled 0
DesiredShadowMethod 0
ShadowsEnabled 0
DesiredDynamicLightQuality 0
SpeedBlurEnabled 0
MotionBlurEnabled 0
ProcessColourEnabled 0
WaterDistortionEnabled 0
EdgeAAEnabled 0
SSAOEnabled 0
RingEffectEnabled 0
LensFilterEnabled 0
AllowVendorExtensions 1
TTAnimationMode 0
UseHires 0
UseHiresPending 0
ForceShaderModel 0
You might try changing the resolution in that manually and see what happens.
DirtyDachshunds
« Reply #2 on: August 09, 2010, 01:31:08 pm »
Code: [Select]
FileVersion 3
ScreenWidth 1024
ScreenHeight 768
WindowWidth 1016
WindowHeight 697
WindowLeft 0
WindowTop 0
VerticalSync 0
FSAA 0
AspectRatio 0
TextureQuality 0
SoftParticles 0
SFXVolume 10
MusicVolume 10
MasterVolume 4
MusicEnabled 1
MouseSensitivity 10
InvertY 0
Vibration 0
BloomEnabled 0
DoFEnabled 0
ShadowsEnabled 0
SpeedBlurEnabled 0
MotionBlurEnabled 0
EdgeAAEnabled 0
SSAOEnabled 0
RingEffectEnabled 0
LensFilterEnabled 0
TTAnimationMode 0
UseHires 0
UseHiresPending 0
ForceShaderModel 0
I'll look for that when I get home.  For what game did you find that file? Just curious.
newmanfamilyvlogs
