Author Topic: MAME32 Joystick Order Issues  (Read 1315 times)
Lumpy
  • Last login:July 13, 2005, 11:27:35 am
  • Doh!!
« on: August 06, 2003, 09:56:03 am »
Could anyone tell me if there is a way to have an I-pac as person one and use a USB sidewinder as player two?  When I plug the joystick in it only gives me the option in MAME32 to use it as player one.  Also are there any other front ends\emulators that I should be using?  Still kind of new on the scene and waiting to scrape enought money together to buy more joysticks and buttons.
« Last Edit: August 06, 2003, 10:45:25 am by Lumpy »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:MAME32 Joystick Order Issues
« Reply #1 on: August 08, 2003, 05:16:55 am »
You have to "remap" mame's inputs.  Four ways
1) "TAB" method:  check out
mame.net FAQ
easyemu specific page, ( easyemu index)
2) "ctrlr ini" files method: check out
easyemu ctrlr ini page
& docs/ctrlr.txt file that comes with mame.
3) "unused joystick" method
Uninstall your current joystick, install a different joystick you won't use, then install the joystick you want to use.  Do not uninstall the unused joystick. :-\
4) "Compile your own" method
edit the mame source and recompile your own binary. ;)
Alright, only the first two are the common solutions.  Personally, I like #2 better, since it is designed to work between mame versions.  #1 is easier to understand, though. *shrug*
Robin
Knowledge is Power
Lumpy
  • Doh!!
« Reply #2 on: August 08, 2003, 02:45:01 pm »
Thank you for the ideas!!!!!
