Author Topic: MK2 low volume  (Read 7915 times)
pinballwizard79
MK2 low volume
« on: August 09, 2010, 02:23:12 am »
So I press F2 & increase the volume = yep I can hear them game while I play, sweet.
Then I exit & go back in = its quiet again.
Any ideas on how to make this thing save it?
"save game state on exit" is checked in mame
Any help would be appreciated, thanks
Edit: ok its just MK2 thats not saving it, me thinks its not save compatible eh?
« Last Edit: August 09, 2010, 02:27:35 am by pinballwizard79 »
The Lumberjackass
  • Last login:January 09, 2015, 08:58:56 pm
Re: MK2 low volume
« Reply #1 on: August 09, 2010, 05:56:06 am »
this very thing happens to me too.
its etremely annoying and takes away from the whole experience of mk2 . ive yet to find a solution for it  :cry:
I may be a jackass , but im no fool !
bigster
  • Last login:June 16, 2022, 08:24:40 pm
Re: MK2 low volume
« Reply #2 on: August 09, 2010, 07:20:06 am »
Go to the in game test menu and turn thevolume up there
Access the test menu through the dip switches
Hoopz
  • Last login:January 24, 2026, 09:24:43 am
  • Intellivision Rocks!
Re: MK2 low volume
« Reply #3 on: August 09, 2010, 08:20:51 am »
Here is how to do it from the Mame FAQ:
Mortal Kombat II / Mortal Kombat 3 / Ultimate Mortal Kombat 3
The volume for this game is TOO LOW!
When the game is running, hit F2 to get to the internal service menu. Hit F2 again to "close" the service switch so that you won't get stuck in the menu. Now, navigate to the "Volume Adjust" option (following the directions provided) and adjust the volume. It's best to keep the volume no more than 80-90% filled as it might cause your sound to be overdriven and crackle. When adjusted, simply exit the menu.
The Lumberjackass
Re: MK2 low volume
« Reply #4 on: August 09, 2010, 05:08:04 pm »
thanks for this , will sort it out on my cab asap  :cheers:
pinballwizard79
Re: MK2 low volume
« Reply #5 on: August 10, 2010, 12:26:19 am »
Thanks Hoopz but that only works on 1 & 3, not 2  :'(
Re: MK2 low volume
« Reply #6 on: August 10, 2010, 12:59:14 pm »
I was about to suggest changing your CMOS battery until I realized you were using mame.  Have you tried save states?  I havent had any issues wit MK2 saving sound setting on my MAME cab
Gray_Area
  • -Banned-
  • -Banned-
Re: MK2 low volume
« Reply #7 on: October 11, 2010, 03:27:33 pm »
Each game in MAME can have its own volume via ini entry (either manually, or through MAMEUI).
-Banned-
severdhed
  • RIP Dinosaur Hippo
Re: MK2 low volume
« Reply #8 on: October 11, 2010, 03:55:15 pm »
what version of mame are you running?  i had this same problem a while back, using an old version of mame.  i then updated to .124 and the problem went away.  there was a change made somewhere a while back that fixed this, i'm not sure if it was at version .124 or before, but i know .124 works fine
