Author Topic: WG 19K7302 dim picture  (Read 2534 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
« on: August 05, 2010, 11:02:45 am »
Ok.
This is a board I just repaired pwr supply section (blown components/transistors, etc).  Picture is pretty decent but is somewhat to dim (cant adjust brightness high enough).  Also there is a darker area (faded) on Right side of screen.  (degauss did not help)
I have tested or replaced most of the larger caps (all 800's, some 300's and 400's).  Where should I go next? More caps?
In theory, there is no difference between theory and practice, but in practice.....there is!!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 19K7302 dim picture
« Reply #1 on: August 05, 2010, 07:30:53 pm »
check r403,404 , c411 in abl
and d302,c343
kardenm
« Reply #2 on: August 06, 2010, 09:58:48 am »
Thanks qrz.  Will do and let you know.
By the way, what does ABL stand for?
kardenm
« Reply #3 on: August 06, 2010, 12:54:41 pm »
All those parts test good along with others I checked while I was at it.
qrz
« Reply #4 on: August 06, 2010, 07:03:08 pm »
"automatic brightness limiter"    ;)
will have another look at the print and get back w/u...
kardenm
« Reply #5 on: August 11, 2010, 02:52:17 pm »
Checked all the components in brightness circuit, all test good.
(D301,302,303)
(R364,366,367,376,403,404,424,425)
(C348,355,369,411)
(Q310).
Is it possible to change one of these components (a resistor maybe) to give just a little more brightness?
qrz
« Reply #6 on: August 11, 2010, 09:40:50 pm »
has the crt's cathode current been checked ?
'bout the only thing left is a weak crt.
for fun , pull one side of the fil resistor on the neck board .33 ohm/2W.
loop FOUR turns of insulated wire around the flyback core ( exposed ferrite opposite main xformer)
ground one side of the loop , connect the other to the filament . and u just made a filament winding  ;)
when powered, approx 8 volts will be applied to the filaments . approx 2 volts per turn
IF the crt is weak, there may be a noticable increase in brightness.  the rejuvenation process would then
be warranted .
no change could be another issue or crt may be to far gone  :(
kardenm
« Reply #7 on: August 12, 2010, 09:44:55 am »
Thanks qrz. I'll give it a try. Sounds interesting and I like to experiment.  I'll let you know.
I know that the problem is not with the crt.  I have another (identical) board which displays on this same crt with normal brightness.  Got to be something on the board.  Right??
qrz
« Reply #8 on: August 12, 2010, 04:11:45 pm »
process of elimination.
yes . if crt is fine on another board , the original pcb has to have a fault.
just a matter of finding it
kardenm
« Reply #9 on: August 13, 2010, 01:48:29 pm »
qrz: Thanks for all your help.
       I think I have things squared away now.  I found another, bare CRT and hooked this board to it.  Works great!  The other, "good" board works well with the original CRT although I have to keep brightness adjustments at max to get a good picture.
My conclusions are that the original CRT and the repaired board are BOTH marginal when it comes to brightness.  The good b CRToard works ok with the marginal CRT and the marginal board works well with the good CRT.  So now I have two useable monitors.  Problem solved for (for now) and the boss is happy.
I do wonder if there is anything I can do to improve brightness on the marginal CRT.  It's good enough for now but will it get dimmer as time goes on?  Is that just something I have to live with?  I can probably keep repairing the boards forever but what is the usual life of such a CRT?
I never did try the experiment you suggested but could do that if you think that will tell me something useful.
« Last Edit: August 13, 2010, 01:53:00 pm by kardenm »
qrz
« Reply #10 on: August 13, 2010, 09:15:05 pm »
sure sounds like a weak crt .
if u don't have access to rejuvenator , or can build one , then boost the filament voltage .
that is what happens on a rejuve anyway. when voltage is applied, it causes a sudden high current ( 100ma)
surge. this often will "blow off crud" from the cathode restoring operable parameters
still just a "bandaid" for the problem  ;)
« Last Edit: August 23, 2010, 06:34:07 pm by qrz »
kardenm
« Reply #11 on: August 20, 2010, 12:21:11 pm »
Think I'll leve this one for now.  Picture is acceptable and lots of other stuff to do.
Thanks again qrz for all your help.
