Author Topic: <Solved> Having an issue with the resolution of a layout  (Read 2517 times)
jimmy2x2x
« on: August 02, 2010, 08:03:00 pm »
In MaLaLayout I have created 2 layouts, with a fixed res of 1280x1024
When I load them into MaLaLayout they are the correct res
When I use the layouts in Mala they are 640x480 and only show a 1/4 of the layout
Cant seem to find whats wrong
EDIT: I edited mala.ini - searched for 640x480, changed it to 1280x1024
« Last Edit: August 03, 2010, 01:53:20 am by jimmy2x2x »
loadman
  • Moderator
    • MaLa
Re: <Solved> Having an issue with the resolution of a layout
« Reply #1 on: August 03, 2010, 03:35:32 am »
Is the setting in Gui - display - misc  ??
jimmy2x2x
« Reply #2 on: August 03, 2010, 05:49:13 am »
That was probably it!
I forgot about that setting, I assumed it would take the res from the layout - which it will unless lo res mode is enabled (I think)
Anyways, done now  - thanks loadman
