Author Topic: Way to set a message or popup before a game loads?  (Read 6223 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
« on: July 25, 2010, 01:30:21 am »
Is there a way to set MA to show a message before a game loads? I want something to pop to say "Hit the Player 1 Coin Button to eliminate any noise while playing." (or something to that effect) before DS games.
Bender
Re: Way to set a message or popup before a game loads?
« Reply #1 on: July 25, 2010, 10:14:38 am »
Yes, you can enable a loading screen then make one in the theme editor that has what you want on it
The only problem is I think that there is only one loading screen so you could only do it for one emulator
methodical
« Reply #2 on: July 25, 2010, 10:58:29 am »
That will work, I only wanted to have it pop up before DS games. Thanks a lot, I'll try it out tonight.
Bender
« Reply #3 on: July 25, 2010, 10:56:26 pm »
wait.... there's already a DS emulator????
methodical
« Reply #4 on: July 25, 2010, 11:00:18 pm »
yes, it's called No$GBA
There's also a program to launch it called No$Zoomer that will make it full screen and enable a few other features (such as a noise suppressor).
It works very well except there's a lot of noise. The noise suppressor works very well but for some reason there isn't a way to keep it on, need to hit a key to turn it on every time you load a game, and some times multiple times during games... hence my want for an alert telling people what key to hit to suppress any noise they might here during play.
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #5 on: July 26, 2010, 04:46:59 am »
desmume has better compatibility for nds games.. try that one out too!
BobA
  • What Me Worry?
« Reply #6 on: February 10, 2011, 08:46:40 pm »
Can you get it to display full screen?
shateredsoul
« Reply #7 on: February 13, 2011, 06:04:38 pm »
yes
CoolBreeze22
  • Last login:April 25, 2011, 08:38:01 am
« Reply #8 on: February 20, 2011, 01:41:32 pm »
Under config. where do you select Nin. DS?
Don't be part of the Problem, be part of the Solution!
Failure is only a temporary setback on the road to success!
~R2
BobA
  • What Me Worry?
« Reply #9 on: February 22, 2011, 02:43:50 pm »
No config for NDS so you have to select a config you are not using such as Sinclair ZX and use it for your NDS program.
