Author Topic: Bartop Question  (Read 1028 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
Bartop Question
« on: July 19, 2010, 08:04:48 am »
Hi I have started building my bartop. I was going to install computer and mame but thinking about just sticking the 60 in 1 Jamma board in now.
My question is if you select a 2 plager game and the board is set to upright, does the second player use layer one controls or would i need two joysticks and 2 sets of buttons?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Bartop Question
« Reply #1 on: July 19, 2010, 08:22:07 am »
Using an xxx-in-1 board in a scratch-build isn't always the way to go, particularly in a Bar-Top. You will need a lot of space for all the wiring and components plus will have to JAMMA wire from scratch so unless you're handy with a soldering iron then you may want to reconsider as the thing could end up quite large.
With specific regards your question; this will depend on the game in question - if it's a 'turn-based' 2-player game, it should be set up to just use a single set of controls, whilst simultaneous games should be set to respond to 2 sets of controls - any xxx-in-1 PCB that's done correctly will be set for this, though there's so many around now it's anyone's guess. Personally I'm not a fan as they're just not as versatile as a PC, many have either sound or graphics glitches caused by their computer brain not being adequate and then of course there's configurability, which is always better with a programmable control interface.
