Author Topic: 22" Touchscreen inwall Jukebox  (Read 4925 times)
struisje
  • Last login:April 17, 2013, 06:22:24 am
  • Keep on Keepin' on
« on: July 16, 2010, 02:11:26 am »
Today I received my 22" fullHD multitouch screen I bought off ebay for $ 215.
I will use it to create my first project. A touch screen jukebox that I will hang in my bar.
the idea is to mount the screen inside the wall and frame it with a picture frame.
Inspiration: http://www.shuttertalk.com/articles/digitalframe
First question I want to ask the pro's: Is removing the case from a touch screen any different then removing a case from a normal LCD screen?
jholman76
Re: 22" Touchscreen inwall Jukebox
« Reply #1 on: July 16, 2010, 02:19:29 am »
Not really except you will probably have a touch sensor over the actual LCD panel. I've taken apart some 17" NEC Touch screens and the only thing different between a touch and non touch model was an extra pane of glass over the LCD panel that senses touch and translates it into mouse clicks.
Of course there was some wiring diffences, but it was generally the same. Just be careful and you will be fine.
joe
  • Last login:December 16, 2025, 04:07:15 pm
« Reply #2 on: July 16, 2010, 08:43:30 am »
Many times thats not even necessary or desirable since the frame creates a professional bezel. Can it mount flush to the inside of the wall?
struisje
« Reply #3 on: July 16, 2010, 10:45:55 am »
I'm gonna have to try that first.
I want the screen to be level with the wall.
when the screen is in the case it is about 3-4 mm deeper
I'm gonna have to try it to see if I can live with that :-)
hopefully I won't have to remove the casing.
gryhnd
« Reply #4 on: July 16, 2010, 11:10:44 am »
Jump over here (and then pull down a page).
I found upon close inspection that the plastic bezel appeared to be an integral part of holding the touch screen glass in place. I did not see the utility of removing it and then essentially having to rebuild it again.  I chose to embed the screen behind a bezel of my own making using thin hardboard.
Completed: No Name Upright
struisje
« Reply #5 on: July 20, 2010, 12:36:13 am »
I will try to fit the whole screen in the wall without removing the case.
But first things first.
Today I will be running some cable from the house to the stables (the stables have been converted into a bar).
Currently I have a 1.5mm Power cable going from the house to the stables. I'm going to change it for something stronger. Now I can hook up about 3600 Watt to it. But when I'm using the waterboiler (2000W) and the fridges and the lighting, it's just not strong enough.
And adding a computer to it won't help much.
Now that we're digging anyway I'm gonna put some coax and some cat6 ethernet cable down as well.
Distance to cover : about 20m (about 22 yards)
Temperature this afternoon: 33°C (about 91°F)  :-[
Pictures to follow.
struisje
« Reply #6 on: August 08, 2010, 06:10:25 am »
We've done some work the last few days.
The distance we had to dig was 45 metres.
I put in a new power cable, grounding, 2 cat6 ethernet cables and a coax cable.
We cut the hole in the wall and placed in the screen.
We still have to make a cabinet for the pc and then mount the speakers in the room.
The 22" touchscreen built in the wall of the bar. We still have to make a frame to hide all the holes. Only the visible part of the screen will show then. The case will be hidden.
Close up of the screen
Picture from the back. For now I put two speakers in there, In the future I will hang them on the walls
Picture from the back with the PC and subwoofer. We will make a custom cabinet for the PC, we're doing some testing with the audio system, but I think I will buy new, more powerful speakers.
Close up of how we keep the screen in place.
« Last Edit: August 08, 2010, 06:12:25 am by struisje »
« Reply #7 on: August 08, 2010, 09:40:45 am »
Wow - cool.  How did you cut the hole in the wall?
struisje
« Reply #8 on: August 08, 2010, 10:42:01 am »
First I drew the lines and made sure it was all level.
Then I used a tool like this (I don't know what the word is in english but in dutch it's 'slijpschijf')
I drilled a hole through the wall in every corner so I knew where to cut on the other side of the wall.
Then i used one of these to remove the remaining concrete and make it even.
TEKNYNE
« Reply #9 on: August 08, 2010, 10:45:38 am »
Top tool is an angle grinder and bottom is a roto-hammer or chisel hammer  or combination cant really tell.
« Last Edit: August 08, 2010, 10:47:22 am by TEKNYNE »
jholman76
« Reply #10 on: August 08, 2010, 11:18:07 am »
that is going to be an awesome install...
for a second there I got your Cristal mixed up with the one we are more familiar with (thanks puff daddy)
struisje
« Reply #11 on: August 08, 2010, 12:05:53 pm »
Haha,
I wish I had enough money to put my old PC on three cases of your Cristal  ;D
struisje
« Reply #12 on: August 10, 2010, 02:50:40 pm »
Update.
I finished the custom cabinet to hold the PC. The PC is in and I finished hanging all the speakers.
I started work on the frame. I cut it from MDF and i painted the first coating. It's drying as we speak :-)
Here are some pictures.
You can see I moved the PC from the cases of beer to the custom cabinet above the screen.
Closeup of the cabinet and the PC inside
Work in progress: the frame to go around the screen
Flaptop
  • Last login:May 02, 2022, 09:04:00 am
« Reply #13 on: August 11, 2010, 11:34:17 am »
Must be Belgium (of een gesofistikeerde hollander ) hoegaarden / palm  :cheers:
Nice bar  , If I had that kind a space I'dd put in some arcade cab /pool .
Schol :)
struisje
« Reply #14 on: August 11, 2010, 02:18:14 pm »
Belgium indeed :-) but the fridge is running empty. I was totaly out of jupiler and leffe :-)
Cheerz
struisje
« Reply #15 on: August 13, 2010, 05:34:50 pm »
I finished the project.
Frame is around the screen, software is finetuned and the computer and cables are worked away quite nicely.
Here are the pictures
Enjoy
Cheerz
JohnEDollar
  • Last login:December 29, 2015, 06:36:55 pm
  • Keep it Smooth...
« Reply #16 on: August 13, 2010, 06:05:01 pm »
struisje:
Congrats on a great project!  :cheers:
What software program are you using to drive you touchscreen jukebox?
- John
struisje
« Reply #17 on: August 13, 2010, 11:11:41 pm »
I'm using AlbumPlayer http://www.albumplayer.com
I like it because it looks very nice (scrolling through albums is very smooth and uses kinetic scrolling like on an iphone)
And everything can be blocked so your user can't break anything (you can block playlist changes, play, pauze and stop buttons, you can block track skipping, fast forwarding and rewinding,....)
I just allow adding tracks to the end of the playlist.
extendedplayarcade
  • The Games You Crave
    • Extended Play Arcade
« Reply #18 on: August 19, 2010, 04:27:14 pm »
Mint job.  Great Idea too.
I looked on ebay for the screen but couldn't find it
what model is it and make?  Thanks in advance
again awesome job
« Last Edit: August 19, 2010, 04:44:52 pm by extendedplayarcade »
struisje
« Reply #19 on: August 22, 2010, 07:03:12 am »
I live in Belgium but I bought it in Germany.
Here's one:
Click me
Please consider voltage requirements. We use 220V, I believe in the US they use 110V
Cheers
XNIF
  • Last login:January 18, 2017, 04:40:32 pm
« Reply #20 on: August 22, 2010, 09:21:20 am »
very nice! That is a cool idea! I You are lucky with the back of that wall. If i wanted to do the same i would end up with the back of the TV in my toilet. Maybe we dutch speaking people should unite in a thread where we can share knowledge on where to get parts. People in the US have it easy, for me in holland it's always a quest on where to get my parts. For most parts i just order them in the US and have to pay a ridiculous amount on shippingcost :(
