Author Topic: Kortek KTN-1401 14" CRT CGA - connection help needed please  (Read 6837 times)
shrunkenmaster
I've just received a brand new Kortek KTN-1401 CRT CGA monitor. I've only ever used cased PC monitors/TVs before so I'm not sure where to go here.
I want to connect this to the MAME PC I have in my Tron Mini/Cabaret that I'm currently building.
I'm in the UK, so I'm operating on 240V with a three-prong plug (earth/live/neutral). The seller told me this was auto-switching for voltage - on the board where the power lead attaches it says 90-265v, so I presume this is OK for the UK. The power lead is a standard US two-prong affair - will I need to do anything here?
The monitor has six wires coming from a connector marked H V E B G R - I'm presuming this is Horizontal Sync / Vert Sync / Earth / Blue / Green / Red ?
I know I'll need an ArcadeVGA card or similar and will need to make up a suitable lead. Can anyone please advise of the best route here?
« Last Edit: July 15, 2010, 03:00:49 pm by shrunkenmaster »
grantspain
Re: Kortek KTN-1401 14" CRT CGA - connection help needed please
« Reply #1 on: July 15, 2010, 06:06:17 pm »
should be fine on 230vac-just make sure you earth the frame
everything else you say is correct
shrunkenmaster
« Reply #2 on: July 16, 2010, 02:46:51 am »
Thanks for the reply grantspain. Can anyone show me how to actually connect these six wires to an ArcadeVGA or equivalent then? And how to properly earth the frame?
Franco B
« Reply #3 on: July 16, 2010, 03:41:20 am »
Ultimarc sell a VGA breakout cable that you can use to connect the AVGA to your monitor. 6th item down [here].
To ground the monitor I would use a standard 3 core cable. Connect the live/neutral to the monitor and then connect the earth to somewhere on the frame.
shrunkenmaster
Thanks Franco. Will grab one along with the AVGA. In the meantime I can work on mounting.
« Last Edit: July 19, 2010, 02:58:56 pm by shrunkenmaster »
