Author Topic: jpac plugged in backwards. Is it done?  (Read 2689 times)
headsupkid01
  • Last login:July 27, 2010, 04:17:12 pm
« on: July 14, 2010, 05:28:04 pm »
I recently got all my stuff together and started installing the PC. I didn't see the two sides of the JAMMA harness and plugged the JPAC in backwards. After i started it up and it didn't work i turned it around and re started it. The windows screen came up and everything looked good but after a few minuets the whole screen got messed up. It looks like a meesed up atari game with the lines going across. Did i mess up my JPAC.  Here are some before and after of the screen.
BobA
  • What Me Worry?
Re: jpac plugged in backwards. Is it done?
« Reply #1 on: July 15, 2010, 02:45:32 pm »
According to the ultimarc site
" NEW VERSION!  Now has inputs fully protected against static discharge and reverse connection, now supports 3 extra JAMMA connections (Tilt, Service SW  and Test)"
Does the windows display no longer come up or does it show and then go out of sync afterwards.
headsupkid01
« Reply #2 on: July 15, 2010, 04:27:25 pm »
I have  a old one bought off of Ebay. But the windows screen will come up every time you turn everything off and restart it. It just gets messed up after a few min. I'm also running a ArcadeVGA 3000 card in a Dell Optaplex and it's too big for the case so i have to leave it open. That wouldn't do anything right? What i know for a fact is. The PC works fine, the monitor and everything else in the cab works because i can plug street fighter back in and it's fine. The other thing is, as those line move across the screen in the 2nd pic. The green LED flickers.
« Last Edit: July 15, 2010, 04:29:06 pm by headsupkid01 »
BobA
  • What Me Worry?
« Reply #3 on: July 15, 2010, 04:42:53 pm »
What resolution are you using when windows is showing and what program are you running after start up?
headsupkid01
« Reply #4 on: July 15, 2010, 05:15:57 pm »
When it starts up it's on the lowest res. I never make it to running a program. It goes to the "found new hardware, do you want to install drivers" window and then everything goes bad. The very first time i got it working the screen didn't mess up for 10 to 15 min. and i started to install the ArcadeVGA drivers but it messed up before i could get them installed. I didn't have .net framework so it wouldn't install them.
headsupkid01
« Reply #5 on: July 15, 2010, 07:17:11 pm »
I'm starting to think the video card is bad
BobA
  • What Me Worry?
« Reply #6 on: July 20, 2010, 09:28:09 am »
Did you uninstall all previous video drivers before you installed the arcadevga?
headsupkid01
« Reply #7 on: July 22, 2010, 10:02:03 pm »
Its a computer that has never had drivers or anything on it. I bought a NEW j pac and i'm still havng the same problem. I have tried different wires, different computer, made shure they both had separate power outlets that were 3 prong,I pluged it in the the vga out that the optiplex  comes with and it's the same thing. All tho it runs a few minutes longer thew the Arcadevga before it messes up than the stock vga out. Do i have to cut one of the wires to the JAMMA before i install it? because the problem is definitely between the J pac and the JAMMA harness. I can send you a video of everything if you need it. but i don't know were to go with it now.
headsupkid01
« Reply #8 on: July 22, 2010, 10:15:07 pm »
Ok the green led go's out and from what i have read this means the frequncy is out of range. I can't install the drivers with out that moniter.
headsupkid01
« Reply #9 on: July 22, 2010, 10:37:15 pm »
Do i have to install the ArcadeVGA card and drivers before i plug it in to the J pac?
headsupkid01
« Reply #10 on: July 23, 2010, 09:10:36 am »
I figured out what was wrong. I plugged everything to my PC threw the DVI port and got this blue screen. Aparentlly the ArcadeVGA card is a defect. Also it did the same lines across my PC monitor that it did on the Street fighter game.
