Author Topic: Template for Ultimate Arcade II  (Read 5862 times)
AzureKnight
« on: July 07, 2010, 06:38:56 pm »
I am soon going to be ordering the Ultimate Arcade II - 4 player combo kit from mameroom.
http://www.mameroom.com/ProductDetail.asp?ID=UAIICAB27E4
Does anyone out there happen to have an image file/template for the dimensions for the 4 player cp?  I want to do some custom artwork and having the right sized image right out of the blocks would sure be helpful.
I located the side art through older posts but had no luck with the cp.
« Last Edit: July 07, 2010, 06:44:30 pm by AzureKnight »
DirtyDachshunds
    • First Project: MillerCade
Re: Template for Ultimate Arcade II
« Reply #1 on: July 20, 2010, 03:30:26 pm »
You can find all of the measurements from their configuration program located here:
http://www.mameroom.com/files/mameroomcpd.zip
I am also building a cabinet using the Ultimate Arcade II with 4 player panel.  Let me know how yours is coming.  I am undecided on the art direct, and maybe I can be inspired by your cabinet.
Cheers :cheers:
AzureKnight
« Reply #2 on: July 20, 2010, 07:19:51 pm »
I have that, I was looking for something in an image format so that I could begin work on the overlay.  If there is a way to go from one to the other I wasn't smart enough to find it  :)
I did contact Game On Grafix and they were good enough to send me a template.  I uploaded it here if you want to have a copy.  Much thanks to Game on Grafix!  I was planning on having them print my artwork before but this certainly sealed the deal for me.
Side panel art template for Ultimate Arcade II
http://www.azureknight.com/arcade/mameroomDrawing.zip
Quad Controller template
http://www.azureknight.com/arcade/quadtemplate_rar.zip
(I'll leave both of these up for a bit, if anyone finds this later feel free to PM me for them if they are gone)
As for my art direction it is horribly bouncing back and forth.  I started a Gauntlet theme, I also created most of a Robotech theme as well as tossing around several other ideas.  I think in the end I will go with the Gauntlet, but if you ask me tomorrow that might have changed!  ???
What ideas have you been considering?
alfredov
  • Last login:February 26, 2015, 09:26:32 pm
« Reply #3 on: November 11, 2014, 10:20:27 pm »
I am looking for the UAII quad controller template. Would any one mind putting up online for me or sending to me at Alfredo at gmail . Com.  Thank you
AzureKnight
« Reply #4 on: November 12, 2014, 11:19:26 am »
I should still have that at home, I changed webhosts a year or so ago and this must not have been transferred.  Let me see if I can get it back up.
AzureKnight
« Reply #5 on: November 12, 2014, 12:03:34 pm »
Even better, I found it on their site:
http://www.mameroom.com/files/QuadTemplate.zip
This is better as it is sure to be up to date if something changes.  If I still have my psd files and they match I will post those as well.
« Last Edit: November 12, 2014, 12:08:40 pm by AzureKnight »
AzureKnight
« Reply #6 on: November 12, 2014, 09:47:55 pm »
Here is the psd version I got from them awhile ago.  You might want to compare it to the current jpg to ensure it is a match.
I added it as an attachment this time so it doesn't get lost again.
