Author Topic: Anyone know the distance between the u360 Magnet and the PBC board?  (Read 1310 times)
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
Working on modding my u360's, but I realized I don't know what the distance was between the bottom of the magnet and the PBC board above it? Does anyone have one they can measure or know off the top?
Also, does anyone know if it must be precise? Or can the configuration utility fix any difference in the gap? (Assuming it's close).
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
Re: Anyone know the distance between the u360 Magnet and the PBC board?
« Reply #1 on: July 06, 2010, 09:31:02 pm »
From what I remember, the magnet is as close to the sensor as you can get without touching when you move the joystick. I believe the edge of the magnet actually touches the sensor on one of my U360s when I move it in one of the 4 directions - the sensor isn't perfectly flat.
pmowry
  • Last login:September 06, 2016, 11:57:00 am
« Reply #2 on: July 06, 2010, 09:41:03 pm »
I'll try to look at mine tonight if I get home before midnight. I need to check one anyway, it does not always return to center. Maybe there is some debris in there. Bur anyway, out of curiosity, what are you modifying?
kronic24601
« Reply #3 on: July 06, 2010, 10:05:49 pm »
I'm adding an LED, but you could easily add a topfire with the same method (I haven't fully researched the rotary ability, but may try that down the road). I have successfully installed a stereo jack into the unit and once I figure out the distance and try out the standoffs I'll create, I'll post a how to with pictures shortly there after.
pmowry
« Reply #4 on: July 07, 2010, 09:21:12 am »
Mine measure 1/8" between the magnet and sensor. Sorry, no mm ruler around.
kronic24601
« Reply #5 on: July 07, 2010, 10:49:47 am »
Thanks! Back to work for me ...
Bender
« Reply #6 on: July 07, 2010, 05:07:33 pm »
two things
1)I got a little less than an 1/8"
2)having done what you are doing I can tell that the standoffs can get in the way of the magnet (especially if because you need a bigger one)
I made "L" shaped brackets that I attached to outside of the plastic base to compensate for the longer space the stereo plug creates. I also had to use a larger diameter magnet because the added length crates more travel for the magnet (it did really funky things with the stock magnet) although there are some fine tuning things you can do if you edit some of the software
good luck and let us know how it goes
and for god sakes take pictures, I was lame and forgot so now I don't have the documentation that would be helpful to you and a few others :banghead: :banghead:
kronic24601
« Reply #7 on: July 07, 2010, 08:58:34 pm »
Thanks Bender ... It was your photos that got me started on this  ;).
I "Think" that I have a way to get around all that without much modification ... so ... we'll see about that.
BTW, how did you mount the magnet to your stereo Jack ... I'm toying with a few ideas but haven't fallen on one yet.
Bender
« Reply #8 on: July 09, 2010, 12:42:03 pm »
I've had success with two ideas, 1st I used two small magnets one actually inside the stereo plug (I think you mean plug, the male part right?) and one inside the aluminum "cup" that holds the sensor magnet, then they just stick together
The other way was much more simple and direct....     Epoxy!
Can't wait to see how you "get around all that" I hope it works cause I'm working on the same thing, basically I'm trying to make an almost completely flat stereo plug that would essentially fit inside that "cup" on the back of the sensor magnet, and it is a pain in the Arse
« Last Edit: July 09, 2010, 12:44:49 pm by Bender »
kronic24601
« Reply #9 on: July 09, 2010, 03:01:52 pm »
Hi Bender,
Well, my "fix" involves using the Circular restrictor, so although it's not ideal for everyone it works pretty well. I've gotten it all to work, but "ideally" I would shave a little of the aluminum off of the magnet outer diameter ... that way it won't hit the sides.
The other alternatives is to lower the restrictor, or find a slightly less tall Male Stereo plug ... currently I'm looking into both.
I had a little setback last night, while unscrewing my ball top, I ended up twisting off my LED ... which is a big problem considering I JB-welded the stereo jack on the bottom ... alas ... back to the lathe she goes ...
