Author Topic: Metal Slug Lowboy *new update*  (Read 12683 times)
XNIF
  • Last login:January 18, 2017, 04:40:32 pm
« on: July 01, 2010, 08:58:39 am »
I just ordered the first stuff for my first (lowboy) build. After long reading (this forum and "the holy book") i've now finally done it.
I've ordered a minipac kit from Gremlin Solutions. And this weekend i'm gonna get a 25" trinitron tv (with scart) and the MDF.
The high pressure laminate will come when the MDF is turned in a cabinet  :cheers:
I'm using the lowboy from RXII ( http://forum.arcadecontrols.com/index.php?topic=68962.0 ) as a reference. However it's gonna be different in a lot of ways. I'm using HPL like i said for some nice art on the side and the CP.  I really liked the Street fighter cabinet from here, i wanna do the same for my lowboy in a Metal Slug theme. This SF cabinet: http://forum.arcadecontrols.com/index.php?topic=84649.0
I'll keep you posted !
A strange thing happened when i placed my order, i started to sweat and shake ! Is this normal, or is this the feeling of an addiction comming?  :lol
« Last Edit: August 19, 2010, 05:59:15 pm by XNIF »
Silas (son of Silas)
Re: Metal Slug Lowboy
« Reply #1 on: July 01, 2010, 03:00:35 pm »
Arcade building is like Hotel California. You can checkout any time you like, but you can never leave  >:D
Welcome to a life long addiction buddy  :cheers:
My Project MAME clone
Who is Silas?
XNIF
« Reply #2 on: July 12, 2010, 09:56:43 am »
Just a small update:
Got my package from gremlin! It look great. I will make some pictures later today. Just to get more colour in my postings :)
This weekend i picked up a Sony Trinitron flattube CRT 25". I want to connect this with a VGA -> RGB scart cable i am going to make. I am not completely sure about how to proceed here... i want to run PC games and Mame with soft 15 khz.
Things to find out:
* Can i set in the frontend to use mame with soft 15khz and normal pc games without?
* Will soft 15khz work with a 9800GTX or a 8800GT (those i have here on the shelf)
will post pics later.
saleem
  • Last login:February 07, 2012, 08:03:39 am
« Reply #3 on: July 12, 2010, 10:48:01 am »
take a bit of advice,when you cut your panels for the cab,sides,front etc laminate them before you put it together.far easier to do and better to handle this way.
XNIF
« Reply #4 on: July 12, 2010, 04:15:21 pm »
Little update with the pics!
The kit I ordered from Gremlin with 18 buttons
The buttons, orange and yellow, the idea is to also use orange T-molding:
The PCB and the harness, thank god i have a harness. Soldering those wires would take forever:
Big-ass 25" sony trinitron for 25 euro(32 dollar):
It will be big :)
XNIF
« Reply #5 on: July 13, 2010, 04:30:44 pm »
I made a basic 3d model with the measurements i am using. It's always tricky to start something without seeing how it looks. So i made this (with some models i imported from google ;)  )
Not bad for a first try, i'll make this better soon. But by the looks of it, it's nice. It has a 20cm control panel at 85Cm height. The total height is 151, i think i just keep it at 150 when it's for real.
« Last Edit: July 13, 2010, 04:33:22 pm by XNIF »
XNIF
« Reply #6 on: July 15, 2010, 05:01:29 pm »
I did not really like the last model i made. It was just not elegant. I know lowboys are just little boxes, but i wanted to add some of the nice designs some cabs have. Also i do not like the way controlpanels look on lowboys so i made one that would have a "normal" CP.
On the model i did not mount the controlpanel yet, but to give you an impression:
« Reply #7 on: July 15, 2010, 05:49:17 pm »
I like your new design much better.  The CP changes were a good idea.  Your design should be real comfortable for playing "classics" like Pac Man where the monitor is more at an angle.
XNIF
« Reply #8 on: July 16, 2010, 05:35:10 am »
Thank you. I hope the design changes will improve the way games will be played. I'm building a lowboy only because it's smaller and easier to fit in my house. So i want to create a hybrid version of a lowboy and fancy normal cabinet.
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
« Reply #9 on: July 16, 2010, 06:24:24 am »
everyone said that about slot car, but that was before i built my first cab!
« Last Edit: July 19, 2010, 02:43:02 am by solidteezme »
XNIF
« Reply #10 on: July 16, 2010, 05:08:39 pm »
Yeah well i am still in the design phase. It's a lot of fun to do a lot of research. I think every part of making the cab has it's own ups and downs.
Look look i made a controlpanel.... spending hours learning Google Sketchup :
XNIF
« Reply #11 on: August 11, 2010, 09:10:06 am »
Ok new update, i started to cut the side panels, you can now see how the design will  look like. I know OSB is not the best material, but i am on a tight budget. So i am using cheap wood and a lot of wood i already have. That way i can save money to laminate it, and have nice artwork.
It's a tight fit, but i have measured correctly the CRT will fit with the right angle.
As you can see i have cut out a piece of wood in the back so it's symetrical, and the wheels will fit nice. The wheels will always hit the ground so it should be sturdy enough.
I am a little worried about the control panel,  i do not know how to attach it (it will fit on top) maybe i should make a little adjustment by cutting a little deeper in the front so it will fit inside.
And after a lot of sanding they are identical twins:
I did not use that saw for cutting by the way. I used that saw for the corners because they were not identical, sanding that difference was too much!
Tonight a friend will help me with the TV (so i won't kill myself) , i'll post more pics soon. if i do not post anything anymore, he did not help me enough ;)
« Last Edit: August 11, 2010, 10:04:18 am by XNIF »
muppets4
  • Last login:October 21, 2017, 08:32:46 am
« Reply #12 on: August 11, 2010, 02:48:54 pm »
Just curious if you're still alive  ;)
This is the reason I'm working at a slim cabinet with an LCD in it. So I don't have to mess with high voltage tubes.
SpaceHedgehog
  • Almost done ...
« Reply #13 on: August 11, 2010, 05:18:29 pm »
Off to a great start. I really like the lowboys so am looking forward to seeing this develop  :cheers:
Click a pic for a video tour
XNIF
« Reply #14 on: August 11, 2010, 05:47:45 pm »
i'm still alive... the tv is uncharged! i'll post an update soon!
mgb
  • North East, US
« Reply #15 on: August 11, 2010, 08:41:01 pm »
Thats a great looking design for a cabinet. good luck with it.
discharging a crt is a  nerve racking thing the first time, then you get use to it.
whenever I work on someones monitor, they always stand far back as I discharge the monitor and then they say "thats it"
XNIF
« Reply #16 on: August 12, 2010, 04:34:44 am »
yes but LCD just doesn't look right for to with 15khz games. It's not bad or anything i just prefer CRT , i'm planning a bartop when this is finished with a 15" LCD.
I guess it's just what you wanna play. PC games look great on LCD.
Gonna cut the front and backpanels right now.
« Last Edit: August 12, 2010, 06:19:40 am by XNIF »
muppets4
« Reply #17 on: August 13, 2010, 10:50:08 am »
That's the reason I have a dedicated MAME cabinet for the 15 Khz, with an ArcadeVGA videocard. The new one will be PC and consolegames (with some MAME games too)
XNIF
« Reply #18 on: August 13, 2010, 03:09:34 pm »
yeah you're lucky ! I do not think my wife will agree when i tell her i must have more than one ;)
muppets4
« Reply #19 on: August 13, 2010, 04:32:22 pm »
I told her it is a surprise for my son......it's all about strategy!
XNIF
« Reply #20 on: August 15, 2010, 05:14:17 pm »
ok update, test fitting the panels:
used construction glue for the bottom.
A control panel is missing :)
from the inside:
Next is test fitting the TV. Then when all panels are done, í'll start with the C.P.
XNIF
« Reply #21 on: August 16, 2010, 03:23:30 pm »
And some more progress. Made the bottomplate and the backside. And i started to with the marqueeholder.
I left the bottom frame uncovered for the wheels. It seemed more stable than mounting the wheels with OSB plate in between.
muppets4
Re: Metal Slug Lowboy *update*
« Reply #22 on: August 16, 2010, 03:39:04 pm »
You're going in a great pace. I like the shape too. And I see you're getting help from "Duke Jan"
Why did you choose that wood? It will be hard to get it smooth.
XNIF
« Reply #23 on: August 16, 2010, 03:50:53 pm »
I cannot do anything without "The Duke", too much shaking of the hands :) That is how i keep pace! Just an hour here, and another two hours there. :cheers:
About the wood... uhm....  well i'm laminating it so it does not have to be smooth. But you are right, i should have used MDF.
We'll just see how this holds. Worst case scenario:  i'll cut the two sides again out of MDF. But this OSB is not that bad.
« Last Edit: August 16, 2010, 03:54:17 pm by XNIF »
XNIF
« Reply #24 on: August 19, 2010, 05:58:49 pm »
Ok new update! Fitted the screen it's starting to look cool. It's a slim fit. I like big screens in little boxes :P
It was almost impossible to lift it by my own and a friend helped me out. Thanks a lot Mayko! Really happy now :)
Did i say it's a close fit? Angle is 30 degrees.
Just enough room :)
  • Last login:September 04, 2025, 07:24:25 pm
Re: Metal Slug Lowboy *new update*
« Reply #25 on: August 19, 2010, 06:57:45 pm »
Nice clean woodwork here, not just the cuts but joinery as well, looking good!
  • Last login:August 17, 2025, 04:58:40 pm
« Reply #26 on: August 19, 2010, 07:04:04 pm »
Yeah, this looks great!
XNIF
« Reply #27 on: August 20, 2010, 04:22:08 am »
comming from you this is a real compliment! Your project is insane! Every detail you do is the best you can do, where I just wanna finish is fast as good as i can in the time i have. I just want to finish it as soon as possible and play!  When my project takes too long i am afraid i will never finish it. So i have set myself a goal to finish the exterior this month.
@emphatic  thanks! I'm trying hard!
SpaceHedgehog
  • Almost done ...
« Reply #28 on: August 23, 2010, 09:38:05 am »
The more I look at this, the more I like it. The extra contouring on the side really adds to the overall aesthetics. You're tempting me into building another cab......
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #29 on: November 26, 2012, 07:39:19 pm »
This thing ever get finished?
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« Reply #30 on: November 28, 2012, 04:40:36 am »
Following with interest. Keep up the good work.
Lowboys are the new bartops.  :D
edit.
Just noticed this was started 2 years ago not sure how I missed it. Hope it was completed.
« Last Edit: November 28, 2012, 04:46:36 am by Termin8tor »
TGov
« Reply #31 on: November 28, 2012, 10:51:45 am »
Ya, neat project.  I am considering building a Lowboy to replace the Dynamo HS-09  I have now.  It is a great cab but is a bit overpowering in my small office.  The footprint isn't a problem but the volume makes it look a lot bigger than it is.
