Author Topic: Anyone use these guns?  (Read 1168 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
« on: June 28, 2010, 06:50:15 pm »
http://www.dealextreme.com/details.dx/sku.32032
Looked like it might be a cheap solution... if they work.
Also, I'm new here... just thought I'd say hi. Been looking through the forums for a while now, building a cab this summer. Figured I'd post this link to see if anyone has used them/knew of them.
jasonbar
  • Last login:September 04, 2025, 11:58:58 pm
  • Dr. Inferno
    • The Infernolab
Re: Anyone use these guns?
« Reply #1 on: June 28, 2010, 07:00:00 pm »
Wow, those are....ummm......loud....   :o
-Jason
bigster
  • Last login:June 16, 2022, 08:24:40 pm
« Reply #2 on: June 28, 2010, 08:45:36 pm »
What are the odds OP works for DE or the manufacturer of the guns?
mytymaus007
« Reply #3 on: June 28, 2010, 09:48:42 pm »
Will you be using an arcade monitor, find out if they work with them
methodical
« Reply #4 on: June 28, 2010, 10:31:02 pm »
Odds are pretty bad. I just happened to see them, noticed there's always a search for guns... finally had a reason to post, thought I'd share since I came across them.
« Last Edit: June 28, 2010, 10:34:16 pm by methodical »
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
« Reply #5 on: June 29, 2010, 06:35:34 am »
They look abit .... hot?
But i think you could live with that if they function like it says they will. A bit pricey tho to just try one out as it were.
Solid
methodical
« Reply #6 on: June 29, 2010, 11:18:22 am »
Just read somewhere that they have pretty bad accuracy :-/
DashRendar
« Reply #7 on: June 29, 2010, 11:24:41 am »
Yeah, without an LED bar or sensors (and an advertised range as far as the eye can see), it seems like they wouldn't be very accurate.
