Author Topic: Space Invader Taito Table Top Restore Help Needed  (Read 26130 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« on: June 24, 2010, 07:44:46 am »
Hi just got a 1979 Taito Space Invader Cocktail but I dont think the game board is space invaders it doesnt work at the min I have found
some Taito stickers with the following numbers but nothing comes up on google
It's got 3 boards the the middle one says Taito TVN00003 and the bottom Board says Taito TVN00002 Serial Number 680435
Any Ideas??
Cheers
Darren
« Last Edit: June 25, 2010, 05:24:22 pm by SirPeale »
Darren01274
« Reply #1 on: June 24, 2010, 08:50:51 am »
Hi I have a cocktail cabinet I purchased of ebay, and the screen is garbled when I turn it on I get about 8 broken blocks on the screen 4 on the left
and 4 on the right. What does this mean apart from it not working I took a photo of the screen but I dont know how to upload it.
Does the broken blocks mean gameboard fault.
saleem
  • Last login:February 07, 2012, 08:03:39 am
Re: Need help to identify Taito game board
« Reply #2 on: June 24, 2010, 09:39:34 am »
well space invaders uses a 3 board set if i aint mistaken.what you should do is go find the manual for the space invader cocktail table and look at the schems for the boards,it will tell you the part numbers/board numbers and if they are the same looks like you have space invader table top.
also this is restoration thread not one for asking technical questions if i aint mistaken.at least keep your questions to one thread instead of creating what looks like 2 already.
do a space invader table top restore and then ask there,also include as much info and pics as possible.all you do is upload to tinypic and copy the link and paste it into a post.
Darren01274
« Reply #3 on: June 24, 2010, 09:54:59 am »
Hi I have this coming up on my Taito Space Invader Machine I have not decided whether to try restore it or gut it and clean it all up and fit a 60 in 1 jamma board in. I will post more pics later. I have checked and replaced all fuses.
Any thoughts on what is the fault? there is also no sound when you switch on the machine.
Chrome legs need sorting out full of rust and the metal base is also rusty. And the top is quite scratched and underlay needs replacing along with the Space Invader Game Cards. Yikes seem a lot of work lol.
« Last Edit: June 24, 2010, 12:13:02 pm by Darren01274 »
Darren01274
« Reply #4 on: June 24, 2010, 09:56:37 am »
Hi Saleem sorry very new here so not sure what to do. I tried to go into the posts to delete could not see how to do it so started a restore thread with the pic uploaded to tiny pic thanks for the help much appreciated!!!
IG-88
Re: Space Invader Taito Table Top Restore Help Needed
« Reply #5 on: June 24, 2010, 04:13:29 pm »
No help really, but you will probably have better luck getting some answers on the KLOV forums. I'd hate to see you gut it. Not a real fun game but a classic none the less. It will be a lot of work to restore but when you are done the satisfaction is well worth it!
Here is the linky:
http://forums.arcade-museum.com/forumdisplay.php?f=9
These guys can sometimes be a little harsh/honest but you will find no better experts anywhere else IMO. Keep us posted on what you decide to do.
-HarumaN
Darren01274
« Reply #6 on: June 24, 2010, 04:37:47 pm »
Hi thanks for the link however because I am a new member I can not post in the forum or something! grrrr very frustrating. Anyway back to the machine, any tips on how to clean all the game boards etc they are full of dust and a lot of dust and muck in the cabinet.
Also if somebody knows where the power supply is located could you point me in the right direction only had time for a quick look around today after picking it up but I only seemed to manage to find transformer and below that was a board with two 1.6amp fuses which was fine.
A photo below of some scratches and chrome legs what was chrome legs at least!
« Last Edit: June 24, 2010, 04:49:19 pm by Darren01274 »
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re: Garbled Screen On Cocktail
« Reply #7 on: June 24, 2010, 04:56:37 pm »
yes it does sound like that.
a pic might help! (to upload click the "Addition Options" link when you create a message and browser the jpg you want to attach. if you want to attach more than one pic use the "more attachments" link)
what game pcb is it?
rchadd
  • Made in Cornwall
« Reply #8 on: June 24, 2010, 05:00:50 pm »
putting in a 60 in 1 is pretty good/easy option as you can use a pc atx powersupply and a pc vga monitor, then rewire the controls to a jamma connector.
that monitor will be black and white and looks like the invaders board is not working anyway...
Darren01274
« Reply #9 on: June 24, 2010, 05:04:32 pm »
Could it be a Power Supply Fault?
saleem
« Reply #10 on: June 24, 2010, 06:06:19 pm »
you would have to get the manual for this cabinet.i told you before,to determine a lot of things you need the schems or are you a clued up person when it comes to arcade machines? cos something tells me you dont have much of a clue,not that i do myself.i have had to learn and have lots to learn as well.
to determine psu voltages you will need to know what they should be to start off with.so get the schems and learn to read them.you need the cabinet wiring diagrams,so you can determine the psu (power supply unit) the wires that connect and what current they should have.then its a case of multimetering the connections and see what readings you get.usualy it should be 5v at the connector,could be a 12v one also,so its a case of checking the psu is running correctly then determining that you get correct readings at the edge connector (thats what fits on the board) then checking ics for voltage.
so theres 3 things to check.
psu.
edge connector.
ics on the board/s.
Darren01274
« Reply #11 on: June 24, 2010, 06:25:17 pm »
Hi yes I have downloaded some but not sure if its space invaders 1 or 2 Taito. Taito 1 seems to fit but I thought that it didnt have overlay strips I thought that was invaders part 2. Will check the voltages tomorrow the cabinet is at my parents house the wife didnt want it in ours LOL.
What's the best and safest way to remove all the thick dust etc from the boards and inside cab, on the transformer etc.
saleem
« Reply #12 on: June 24, 2010, 06:57:53 pm »
space invaders part 2 is color so does not need a color overlay on the monitor.as it outputted color pic onto a color monitor.
use hoover and a soft paint brush to clean the boards up.remove the ics that are socketed and clean the sockets and the ics then put them back before moving onto the other.
your name has 01274 in it,you wouldnt be from bradford would you?
happens to be where i am from.
rchadd
  • Made in Cornwall
« Reply #13 on: June 24, 2010, 08:11:51 pm »
rchadd
  • Made in Cornwall
« Reply #14 on: June 24, 2010, 08:31:55 pm »
everything si by the looks of it...
http://www.brentradio.com/SpaceInvaders.htm
IG-88
« Reply #15 on: June 24, 2010, 09:07:30 pm »
Never thought about the monitor being black and white. Not really a good use for a 60-1.
As for cleaning the boards, I'd throw them in the dishwasher before "hoovering" them. Static electricity and fragile, 30+yr old electronics don't mix.
The inside of that cab actually looks pretty good for as bad as the outside looks.
Not sure why you couldn't post on the KLOV forums, I see newbs on there all the time.
-HarumaN
Darren01274
« Reply #16 on: June 25, 2010, 03:05:44 am »
Hi Guys thanks for the replies. I never thought you could put all the boards in water thought it would ruin the roms etc. I think it's deff a Space Invaders 1 with the Colour strips just put over. The boards on that space invaders are slighlty different than mine also mine got 3 boards to it and does not have that power supply. If it had I have 2 working power supplys I could have just changed it over.
When I thought about making it into a  60 in 1 I was thinking of sticking an LCD in there like the ones on Flea Bay have. Also would have to change the joystick and add at least another button to the cabinet. I did not really want to go down that route it seems a shame to make an original cab into a 60 in 1
Hi Saleem yes I am from Bradford nice to meet somebody local on here. I really like this forum I spent ages looking through most of the restorations and projects last night that you guys have done on here well impressed.
If I get time today I am going to check them voltages and see what comes up. What's the best way to remove the ics that are socketed do they just pull out?
Fun Times lol. Also I have noticed the Coin Door and box missing and it still got the old 10p coin slot with numerous old 10p's in it.
« Last Edit: June 25, 2010, 03:08:46 am by Darren01274 »
Darren01274
« Reply #17 on: June 25, 2010, 04:58:37 am »
Hi I have just tested the voltages to both the sound board and the bottom board. All the voltages are either very slightly under or over +12dc reads 12.6 and +5 reads 4.96 on meter? So power must be getting to the boards ok.
I have not yet took out the ICS and cleaned and replaced keep getting broke off at the min by the phone or the wife lol
saleem
« Reply #18 on: June 25, 2010, 05:12:19 am »
the reading just being slightly under or slightly over would be acceptable.
go check an ic while the cab is powered up.the ones that have 74 at the start,could have letters before the 74 but,the number usualy starts with 74,you just need to put the multimeter probes on 1 leg in each corner,so one on the top left and one on the bottom right.see if you get reading from it.
Darren01274
« Reply #19 on: June 25, 2010, 05:30:14 am »
Which board is that on?
Darren01274
« Reply #20 on: June 25, 2010, 05:46:04 am »
Found them yes meter readings of them all?
saleem
« Reply #21 on: June 25, 2010, 08:35:51 am »
then i seriously doubt its power related.
sometimes if you dont know what your doing its best to get them repaired by someone who does.
Darren01274
« Reply #22 on: June 25, 2010, 09:00:03 am »
How much would new Space Invaders Boards be for this? and where could the boards be repaired and what would the aprox cost be. Is it worth repairing or just go with the 60 in 1 Jamma and LCD Screen?
saleem
« Reply #23 on: June 25, 2010, 09:11:31 am »
noone can realy quote you the repair,its a case of haing someone look at them,if they know exactly what is wrong thenm they can quote you based on that,or it ends up being a case of,they fix one thing and find out the next thing in line needs repair/replace.so they bill you at the end.
as for replacement boards? you can only look around and shop,ebay,forums etc etc.
i mean,a 60in1 will cost you,the board,the wiring harness as its jamma.the lcd monitor and you will need a switching power supply i would think.i dont think the current transformer will do,unless i am wrong and it can be used.ontop of that,you will end up having to replace both sticks to 8 way ones and you will need idealy 3 buttons although you might get away with 2.
i might be able to help to a certain degree,as i have 2 magsticks and many buttons and microswitchs.if you went mame,i have a minipac and harness.
so if you need a couple of good sticks and buttons i got some for sale.
Darren01274
« Reply #24 on: June 25, 2010, 09:25:24 am »
I set my other cocktail cabinet up for mame running mala frontend and the new version of mame it was the USA cocktail type. Would have kept that played really well but too big for house really. Was thinkng of making this one a mame but the 60 in 1 sounded less hassle also you can use ATX power supply with the 60 in 1 which I already have.
Bit gutted about not getting it to work :P-( lol
Darren01274
« Reply #25 on: June 25, 2010, 09:38:36 am »
So if I go with either Mame or Multi Jamma Game Board what would you do with the rest of the cabinet. Should I get the legs re-chromed and sort out the top, the wood work and laminate is in pretty good knick apart from them scratches on one side.
I still need to sort out what to do about the coin door and need to change the locks which I already have and guess need to strip the cabinet inside bare and give it a good old clean years of dust in there!
saleem
« Reply #26 on: June 25, 2010, 10:30:41 am »
sell the parts,there are many people out there that will bite your hand off to get that invader boardset.for them its just repair as it will cost them very little to get them running.then theres the harness but,just dont cut it,disconnect it at the connectors,then strip the rest down.
as for chroming.i was at cas coatings which is in eccleshill today as they shot blast my space zap's midway coin door,they do an equivelant to chroming,its a shiny silver coating.so perhaps they might be worth ringing,you can google them to get the number.they can also shot blast the legs beforehand.
like i say i got 2 magsticks,buttons and a minipac and harness,i even have a spintrak spinner.if someone offers me enough dosh they could persuade me to part with some bits.
Darren01274
« Reply #27 on: June 25, 2010, 12:24:47 pm »
Hi I noticed on the wiring diagram for the edge connectors it said The Power-On-Reset (top board pin 10) must be tied to earth or the game will not run! so I followed the wire all the way back to the power supply which amazingly dust free! and it went into a connector with some other leads. Anyway I decided to cut the wire and fastened it to the cab.
Now when I switch on the machine the screen is no longer garbled but I get a few thick horizontal lines on the monitor? what does this mean.
SirPeale
  • Green Mountain Man
« Reply #28 on: June 25, 2010, 05:25:11 pm »
I merged all three of your threads (one project to a thread, please).  And please restore this!  60-in-1s are just not the same.
Darren01274
« Reply #29 on: June 25, 2010, 05:40:43 pm »
Hi I would love to restore it. But struggling at the minute not sure what else to try, apart from looking for new game boards and they seem non existent.
rchadd
  • Made in Cornwall
« Reply #30 on: June 25, 2010, 05:53:28 pm »
if you want your invaders board tested and repaired have a word with andy
http://www.andysarcade.net/
maybe he can help or at leqast suggest somebody in the UK that can help you out
rchadd
  • Made in Cornwall
« Reply #31 on: June 25, 2010, 05:55:36 pm »
well if you do resotore you could consider making an adaptor and use it to play 60 in 1 as well :)
thats what i am doing with my Galaxian - i am making 2 different control panels :)
SirPeale
« Reply #32 on: June 25, 2010, 06:13:23 pm »
The most important thing is to take your time.  If you try and rush things you'll F it up.  I speak from experience.
Darren01274
« Reply #33 on: June 25, 2010, 06:31:19 pm »
So what would you do with it? I contacted an arcade repair place who said they will look at it for £50 and then it may cost £200 plus if the boards can be fixed if it is a board issue. They said the machine would be worth about £500 when fully working.
rchadd
  • Made in Cornwall
« Reply #34 on: June 25, 2010, 06:43:22 pm »
well andy had working space invaders boards for 80-125 quid
maybe he would make a part exchange deal for your non runner or have a go at repairing if for you at an hourly rate
give him a call
otherwise do some research online for si repair logs that report similar issue as you are seeing at the moment to give hints on where to start. does the si manuals have a troubleshooting guide?
issue with old boards will always where to get replacement chips...
sad fact is it could simplly be a matter of a short circuit or failed chip - finding the potential fault is the difficult bit
« Last Edit: June 25, 2010, 06:44:56 pm by rchadd »
Darren01274
« Reply #35 on: June 26, 2010, 05:12:05 am »
Hi where is Andy based and do you have a contact number. Also do you know anywhere to get a glass top made, the one on this one got scratches all over it.
saleem
« Reply #36 on: June 26, 2010, 05:26:12 am »
why dont you contact him through his web site,he will let you know,after all you will need to send the boards to him.all i can tell you is he knows his s**t.you can get him through ebay as well,he sells board on there.
Darren01274
« Reply #37 on: June 26, 2010, 10:13:31 am »
Cheers guys, is there a way of getting the scratches out of the glass or is it a new top.
saleem
« Reply #38 on: June 26, 2010, 10:28:21 am »
have you tried google,i should think theres lots of tips and tricks to get rid of scratchs.trouble with a lot of table tops is they tend not to have the original glass and the replacement is or can be smaller but,getting a top cut shouldnt be a problem.
Darren01274
« Reply #39 on: June 26, 2010, 11:14:25 am »
I had an idea that I would remove the glass and try strip off the paint from the underside and repaint the scratch side black. But getting the paint of might be hard work and probably easier just getting a new glass top cut lol.
