Author Topic: testing optocoupler  (Read 7209 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
testing optocoupler
« on: June 16, 2010, 11:18:49 am »
And finally (well, maybe not), is it possible to test an "optocoupler" #PC123Y11 ??
In theory, there is no difference between theory and practice, but in practice.....there is!!
BobA
  • What Me Worry?
Re: testing optocoupler
« Reply #1 on: June 16, 2010, 04:55:47 pm »
See Link
Your particular IC has 4 leads so you do not have access to the base of the transistor.
« Last Edit: June 16, 2010, 04:57:36 pm by BobA »
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #2 on: June 16, 2010, 04:58:14 pm »
see your other post...
MonMotha
« Reply #3 on: June 17, 2010, 01:57:13 pm »
An optocoupler is basically an IR LED and a phototransistor inside a package with the LED pointed at the transistor photo sensitive base.  They're difficult to fully test except to simply test overall functionality.
You can at least check that the input LED isn't blown by using a multimeter on diode check.  It should read about 1.2-1.7V forward and much higher (usually 10+) reverse if it doesn't read open.  If it reads shorted (~0V) in either direction, very high (>2.2V) forward, or low (<5V) backward, the LED on the input is probably blown up.  The input LED is usually what goes for me, so it's a valid check.
Checking the output transistor is a lot harder since there are often hidden diodes and resistors, and there's no exposed base.
If you'd like to do a functional test, it's not that hard, but I'd probably want to draw up a circuit rather than try to describe it.  Probably easier to just replace it if suspect.  They're not expensive.
kardenm
« Reply #4 on: June 17, 2010, 02:28:43 pm »
Mine test open (over limit) in both directions (using diode test on LED side).  I guess that means it's bad.  Right?
Thanks for the info.
BobA
  • What Me Worry?
« Reply #5 on: June 19, 2010, 07:45:49 am »
If you are open both ways on the input LED side then it is kaput.
kardenm
« Reply #6 on: June 22, 2010, 12:57:38 pm »
Thanks all.
I'll keep plugging away at this one.  May take me a while to get a replacement.
