Author Topic: My Shopping List  (Read 1862 times)
railz
  • Last login:July 04, 2003, 08:06:33 am
My Shopping List
« on: August 02, 2003, 12:29:49 pm »
4' x 8' x 3/4" MDF - $20.95 per sheet (x 3)
Batton Wood - $4.95 per strip
GB Electric Toolbox (stripper, criper, multimeter and other stff) - $21.98
Quick Disconnects - $5.99 per 100
Heat Shrink - $1.14 per pack of 5 tube strips
Wire - 9.99 to 14.99 per roll, depending on guage
Black and Decker cordless three-piece toolkit (saw, screwdriver and drill)
$39.99
Adjustable Hole Cutter - $6.99
Wood Boring Bits - $3 each
Bit Set $8.99
Wood Clamps - $11.98
Hot Glue Gun - $7.99
Soldering Iron - $12.98
I have no tools and no one to borrow from so I have to get everything :(
Routers were between $60 and $180
Anything else?
BobA
  • What Me Worry?
Re:My Shopping List
« Reply #1 on: August 02, 2003, 02:06:52 pm »
Wood glue
Screws
Countersink Bit
Tie Wraps
BobA
railz
Re:My Shopping List
« Reply #2 on: August 02, 2003, 02:53:35 pm »
Check!
(although the countersink bit is in the kit).
Wood glue - I take it Elmers is a no no?
railz
Re:My Shopping List
« Reply #3 on: August 02, 2003, 02:55:58 pm »
Oops and what screw size should I go for? I guess since the MDF is 3/4" and the batton wood is about the same, 1" or 1 1/4 wood screws would be okay?
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re:My Shopping List
« Reply #4 on: August 02, 2003, 03:23:31 pm »
I used #6 1 1/4 wood screws on mine and they worked out just fine.  Although I used oak plywood, not sure if something else would be better for MDF.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:My Shopping List
« Reply #5 on: August 02, 2003, 05:31:54 pm »
Yes, elmers sucks for real woodwork.
I use "Titebond II", but there are others that work too.  I hear the one with the gorrilla on the front is great (don't remember the name ATM).
As for screws, IIRC used 1 1/4" #6 also (might have been #8), but on partical board.  Be sure to pre-drill holes for the screws with MDF and partical board.
Robin
Knowledge is Power
BobA
  • What Me Worry?
Re:My Shopping List
« Reply #6 on: August 02, 2003, 06:31:36 pm »
I used 1 1/4 #6 drywall screws because they have a coarse thread that seems to hold well in MDF.  As said previously you must predrill MDF.
For glue a polyurathane type works really well.
http://www.elmers.com/product/product_page.asp?pCode=P9402
BobA
