Author Topic: Unrelated - help with graphic design  (Read 774 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: June 14, 2010, 02:43:45 pm »
My advisor uses this image to illustrate her theory.. I really wants the text to stay within each area of this shape (pentagon?), can someone suggest software that would let me do this easily?
Would word let me do this?
« Last Edit: June 14, 2010, 02:45:36 pm by shateredsoul »
NiN^_^NiN
Re: Unrelated - help with graphic design
« Reply #1 on: June 14, 2010, 07:00:19 pm »
Well cheapest option is you can use work and apply the image then text boxes around the image to keep them in the shape this is assuming you have word already otherwise im not much help as i use Photoshop and would just use that to do it.
« Reply #2 on: June 14, 2010, 08:59:32 pm »
Word'll do it. Like NIN, said, you'll want to use textboxes to float the text and you'll have to position line breaks and use kerning judiciously.
shateredsoul
« Reply #3 on: June 14, 2010, 11:24:17 pm »
Thanks! Took forever, but I managed a nicer version.
