Author Topic: U360 Question  (Read 1331 times)
snatex
  • Last login:September 22, 2014, 11:32:11 pm
U360 Question
« on: June 14, 2010, 11:55:55 am »
Do you need to go into the U360 mapping program each time you want to change the mode from 4-way, 4-way Qbert, 8-way, etc.?   I am thinking of using these joysticks for a kids cabinet and I don't want them to have to do any adjustments to the settings.
Edwards80
  • Last login:April 15, 2011, 08:44:26 am
Re: U360 Question
« Reply #1 on: June 14, 2010, 12:10:30 pm »
No, once you have loaded the maps into MAME, it will do it without touching the config at all. I've only set a map for q-bert so far but it works perfectly. Mame does a good job with the analogue U360 map for 4/8way etc.
Hey Dudes thanks, for rescuing me, lets go for a burger.... HA! HA! HA! HA!
sstralkowski
  • Last login:July 09, 2012, 03:14:38 pm
  • Rock Out with Macaque Out!
Re: U360 Question
« Reply #2 on: June 14, 2010, 02:37:49 pm »
Would this type of Joystick be good for a Cab that was running both old school 4-way games and something from say N64?
Ginsu Victim
  • Comanche, OK -- USA
Re: U360 Question
« Reply #3 on: June 14, 2010, 02:40:36 pm »
Definitely. It can switch from 4-way to analog.
sstralkowski
Re: U360 Question
« Reply #4 on: June 14, 2010, 02:42:48 pm »
Where's the best place to buy one of these for a decent price?  How much different are they to wire?
Ginsu Victim
Re: U360 Question
« Reply #5 on: June 14, 2010, 02:47:47 pm »
In the US, buy it through divemaster127 (www.arcadeemulator.net) - you'll save on shipping.
If not, buy it from www.ultimarc.com
Wiring is super simple. It hooks up via USB. You can also add up to eight buttons via the built-in encoder.
Add the medium spring and circular restrictor for the best stick possible. (Also, try the longer shaft for installing in wood)
sstralkowski
Re: U360 Question
« Reply #6 on: June 14, 2010, 02:50:23 pm »
Thank you.
EDIT:  Is this the same as the U360?
http://www.arcadeemulator.net/cgi-bin/shop/cp-app.cgi?usr=51F2772352&rnd=5931552&rrc=N&affl=&cip=&act=&aff=&pg=prod&ref=Perfect360ElectronicJoysti&cat=Joysticks&catstr=HOME:Joysticks
« Last Edit: June 14, 2010, 02:53:22 pm by sstralkowski »
Ginsu Victim
Re: U360 Question
« Reply #7 on: June 14, 2010, 03:00:38 pm »
No. There is an Ultimarc section on that site.
shortened link
SammyWI
Re: U360 Question
« Reply #8 on: June 14, 2010, 06:21:51 pm »
You can also use a front end with a U360 plugin to load custom maps for the stick.  Personally I use GameEx and it works great, I believe Mala also has a plugin.
I like the stock, lighter spring myself.
