Author Topic: It has begun - new pics!  (Read 5328 times)
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« on: August 02, 2003, 04:23:36 am »
well it has begun, I spent the better part of the week cutting, routing, clamping, glueing etc. here is the fruits of my efforts (so far) lots to go yet.  but it's the UAII cab with a twist I can break it down in to upper and lower halfs for easy moving.  I'm gonna make the control panel easily removable as well other wise I would never get it out of my basement  ;D
« Last Edit: September 14, 2003, 11:23:38 pm by MiKman »
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re:It has begun :-)
« Reply #1 on: August 02, 2003, 07:16:28 am »
Nice looking cab I really like it!, but why such a big coin door it looks like its almost touching the floor.
Gary
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
Re:It has begun :-)
« Reply #2 on: August 02, 2003, 09:20:55 am »
Looks good!
I'm using that tv as well.
MiKman
  • Blah
Re:It has begun :-)
« Reply #3 on: August 02, 2003, 11:16:41 am »
Gary
Ya it sucks, it's an over/under coin door. got it before I knew how big of space I needed to fit it into.  It goes all the way to the bottom edge which is ok, the cash box can slide right in and sit on the bottom of the cabinet.  It 'just' fits in the space provided.  When I get it all painted then it will blend better I hope.
« Last Edit: August 02, 2003, 11:18:54 am by MiKman »
MiKman
  • Blah
Re:It has begun :-)
« Reply #4 on: August 02, 2003, 02:51:14 pm »
Looks good!
I bought it on the assumtion that it cam eback on when unplugged and plugged back in cause it does, but after about 15min of being unplugged then plugged back in it doesn't come back on  :-\  ahh well I have decided to just use the tv remote to turn on the whole cabinet. I'm gonna get one of those smart strips and plug the tv into the Hot outlet and when the tv is turned on (via the remote) everything else should power up.
meta87
Re:It has begun :-)
« Reply #5 on: August 03, 2003, 10:17:40 am »
Another option is to jam a piece of wood into the power button, (So it is stuck on)
Then if you unplug it and plug it back in it works!
MiKman
  • Blah
Re:It has begun :-)
« Reply #6 on: August 04, 2003, 12:28:41 am »
really?  you have tried this with your RCA?  sweet I didn't give that a try, I saw thats what some people were doing, but I didn't know it would work with my TV, thanks.
meta87
Re:It has begun :-)
« Reply #7 on: August 04, 2003, 02:11:16 am »
Yah I'm not sure if that is the same model, but it worked for me. :)
MiKman
  • Blah
Re:It has begun :-)
« Reply #8 on: August 04, 2003, 08:36:44 pm »
Here it is with Primer and a first coat of black satin latex paint, starting to look like a real cabinet now  :D  can you tell I'm getting excited?  I still have a lot to go tho, the control panel hasn't even been started or designed really, got some sketches and an old protype that I have been playing on while I work on the cabinet.
NatasNJ
  • Last login:December 19, 2003, 04:10:03 pm
Re:It has begun :-)
« Reply #9 on: August 04, 2003, 09:27:37 pm »
Looks like mine at that stage.. :)
Keep up the good work.   Can't wait to see your control panel and what artwork you add to it..
SNAAAKE
  • -Banned-
Re:It has begun :-)
« Reply #10 on: August 05, 2003, 08:15:28 pm »
Since we are posting pics !
Here is mine... :D
MIKman,looking good so far.keep us updated !
« Last Edit: August 05, 2003, 08:16:31 pm by SNAAAKE »
TalkingOctopus
    • My Arcade
Re:It has begun :-)
« Reply #11 on: August 10, 2003, 11:39:29 pm »
Instead of actually using the remote, you can take it apart and wire the power button of the remote to a pushbutton and put it on the back of your cab.  Then remove the IR transmitter, extend it with wires, and put it right next to your tv.  I did this with an RCA universal remote ~$8, instead of using the actual TV remote.  My IR sensor was covered so I had to find an alternative.
MiKman
  • Blah
Re:It has begun :-) new pics
« Reply #12 on: September 14, 2003, 11:23:17 pm »
Some latest pictures.  I think I should have finished it before I fired it up :-) I don't think I'll ever do the finishing touches now haha well it will be a long cold winter I will need something to do.
MiKman
  • Blah
Re:It has begun - new pics!
« Reply #13 on: September 14, 2003, 11:25:03 pm »
Doh that last one was a little huge!  The marquee is just an old poster I had laying around.  I intend on making something decent eventually :-)
« Last Edit: September 14, 2003, 11:26:28 pm by MiKman »
Apollo
    • Eight Bells
« Reply #14 on: September 15, 2003, 12:11:39 am »
Ha ha I can't believe you wired up your CP without finishing it! LOL.
Great job on the cab I guess you'll get bored one day and take the CP to bits so you can finish it but it may never happen. What a shame it was looking like being a real class effort, well done.
