Author Topic: Unload JoytoKey from command line?  (Read 8065 times)
jimmy2x2x
« on: June 10, 2010, 11:32:41 am »
Is there anyway to unload joy2key from the command line, or kill the process?
Maybe an alternative program that can unload from command line?
I want to use it to use daphne launched from mala via a batch file.
My joystick is a hacked 360 pad that uses the POV for the stick, this cant be used from within daphne.
I don't want to use joytokey all the time as it introduces latency on the controls.
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
Re: Unload JoytoKey from command line?
« Reply #1 on: June 11, 2010, 09:53:34 am »
Yes, taskkill.  "Taskkill /F /IM joytokey.exe"  I use it in several batch files that start joytokey, depending on the emulator.
jimmy2x2x
« Reply #2 on: June 12, 2010, 06:05:52 am »
Sounds just like what I need.
Im trying to put these into mala as pre and post commands, but it doesnt seem to work for me.
ie:
Other emu config  /daphne/execution/pre commands/c:\emulation\joy2key\mame.bat
where mame.bat is:
cd c:\emulation\joy2key\mame
joytokey mame
when I try and run a daphne game, it doesnt get to the game, just loads joytokey with the mame.cfg and waits for me to close the cmd window.
after I close the window, daphne loads and works fine with my config, exits fine and closes joytokey like I want.
Do I have to load joytokey as a service or something to overcome this?
« Last Edit: June 12, 2010, 07:07:38 am by jimmy2x2x »
nick3092
« Reply #3 on: June 12, 2010, 09:45:29 am »
I think you might need to use "start" and "start /wait" options in your bat file.  They tell windows to move on to the next line, and to wait until the program closes, respectively.  I never tried putting them in the pre/post MaLa commands.  I also checked the option in joytokey to go straight to the task bar to avoid the window opening.
For example, here is what I use to launch my Daphne games:
start joytokey.exe
start /wait C:\Emulators\Programs\daphne\daphne.exe astron vldp -framefile (etc...)
taskkill /f /im joytokey.exe
jimmy2x2x
« Reply #4 on: June 12, 2010, 10:12:48 am »
That did it!
Many thanks ;)
Might be time to buy a keyboard encoder haha
