Author Topic: how to figure out if my pc has an PCI-E or AGP graphics card?  (Read 1663 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
I need to figure this out to get the proper driver, I bought it from hp.. so I'm not sure.
Franco B
Re: how to figure out if my pc has an PCI-E or AGP graphics card?
« Reply #1 on: June 05, 2010, 07:26:45 am »
I'm no PC expert by any means. However a quick google gave me this image:
If you dont want to take your card out you may be able to find out by running some software. I found a thread [here] that may help.
If you know the model of your PC/mobo someone may be abe to tell you purely from that.
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« Reply #2 on: June 05, 2010, 09:49:02 am »
Are you sure you even have a graphics card?  You may be using onboard graphics.  A model number would help.
Even if you are using onboard graphics you may still have a graphics card slot.  How old is the computer?  That would give a fair indication.
mr_doles
  • Last login:November 25, 2025, 08:42:10 am
« Reply #3 on: June 05, 2010, 10:29:46 am »
SIW.exe is a great tool to use.  Under go to Hardware and system slots.  I use the freeware version without installer.
« Reply #4 on: June 05, 2010, 10:37:24 am »
device manager, whats it say?
syph007
« Reply #5 on: June 05, 2010, 10:48:29 am »
If you're just trying to figure out what graphics card you have, Device Manager should list something under Display Adapters.  Example: Mine says Radeon x850.
shateredsoul
« Reply #6 on: June 06, 2010, 04:16:50 am »
I ask because when downloading the drivers for my graphics card it gives me the option of choosing one for a PCI-E or AGP card for the same driver... not sure if it makes a difference but I tried the PCI-E one and it worked fine.
I know which graphics card I have, its a ati radeon hd 4850
beastathon
  • Last login:October 22, 2019, 02:55:53 pm
« Reply #7 on: June 06, 2010, 10:15:42 am »
ATI has released both a PCI-E and an AGP version of the HD4850. The easiest way to know is to take out the graphics card from your computer and look at the images Franco B posted, but it's most likely that you have a PCI-E card because AGP cards really aren't in demand anymore because it's old technology.
It seems like you've already downloaded the PCI-E drivers and it's working fine, so I would assume that's the type of card that you have.
