Author Topic: Control Panel Slant Question  (Read 3584 times)
Desolis
  • Last login:July 26, 2010, 12:28:59 am
« on: June 04, 2010, 12:19:25 am »
Hi guys, Been reading over the site for a few weeks and just recently signed up. Love so many of the projects all of you have done. I've got the rulers, pencils, and graph paper out and I'm drawing up the plans for my first cabinet. I've looked around at some of the other projects and have tried to get an idea as to the answer to my question, but my results have been sketchy at best.
I'm wondering if there is a standard or recommended angle to slant the control panel at? For example: If i have a CP that is 24"x 12" and the box at its rear point is 6" tall what would be a good height to make the front of the box to add a comfortable slant?
DashRendar
Re: Control Panel Slant Question
« Reply #1 on: June 04, 2010, 12:33:29 am »
It's a personal preference.
That said, people tend to raise the back 1 1/2" to 2", depending on the depth of the control panel and the desired slant.
If you want it in terms of angle, that's around a 15 degree angle.
Desolis
« Reply #2 on: June 04, 2010, 12:34:30 am »
Perfect. That's what I needed to know. I was leaning towards 2" already. Thank you much.
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« Reply #3 on: June 04, 2010, 09:47:56 am »
I would say less is more.  I just redid my control panel box because I thought the slant was too much.  It was originally about 18 degrees and I've revised it to about 10 and I'm much happier.
gwjrabbit
  • Last login:January 13, 2014, 02:43:00 pm
« Reply #4 on: June 04, 2010, 10:03:17 am »
I went with 11 degrees, with the caveat that even that feels too much on my analog stick.  Great for basic button mashing though.
syph007
« Reply #5 on: June 04, 2010, 01:21:42 pm »
I did a rise of 1 inch over 1 foot... whatever angle that works out to.  Bit of advice.. the taller you are the more painful it is to play on a steeply angled panel.
Desolis
« Reply #6 on: June 06, 2010, 10:47:54 pm »
Thanks for all the advice guys, I decided to go with a 1 inch over one foot as well. I'm trying to keep the CP about 24X12" so I figured that would be enough. I'm relatively short. :)
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« Reply #7 on: August 26, 2010, 10:09:22 pm »
4.76 degrees.
Did hte math just now because I am planning my cabinet.  Cutting starts tomorrow.
I think I am going with a slight, almost unnoticeable angle.
MY FIRST BUILD:
SephYuyX
  • Last login:November 28, 2013, 11:40:04 am
  • I Am, Who I Am.
« Reply #8 on: August 27, 2010, 08:25:00 pm »
I did mine 1" as well, over like uh, a foot or so.
ragnar
« Reply #9 on: August 29, 2010, 05:21:35 pm »
Right now, my rough plan is to do about 1/2" over 10 inches.  I'm of the less is more school of CP slant.
MY FIRST BUILD:
