Author Topic: Mala Crashes after using Fuzzy Renamer  (Read 2274 times)
IG-88
« on: May 29, 2010, 05:17:13 pm »
For some reason after I renamed my snaps to match my Nes romset Mala has started to flake out on me. It will run through the game-list to about a 100 games then almost every game after that I get an error message saying that it ran into an unexpected error and had to terminate. Weird thing is that if I delete the snaps it works perfectly. I know the roms are ok, and the rom files and snap files match, so I cant figure it out. Here is the error log:
2010/05/29  15:09:37.03   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 01CED000
2010/05/29  15:45:21.23   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 01CED000
2010/05/29  15:45:21.25   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 01CED000
There was plenty more to the log besides this, I just cut it short to make it easy to see.
Anybody got an idea what I'm doing wrong here?
-HarumaN
loadman
  • Moderator
    • MaLa
Re: Mala Crashes after using Fuzzy Renamer
« Reply #1 on: May 30, 2010, 10:39:26 pm »
Try with the next MaLa beta version to see if this helps as it uses a different library.
New beta available for testing very soon
mh12
  • Last login:December 24, 2010, 10:03:57 am
« Reply #2 on: May 31, 2010, 10:25:39 am »
woohoo!
IG-88
« Reply #3 on: May 31, 2010, 01:38:34 pm »
Well...I think I got it figured out. I just re-sized my images too 231x200 and now everything scrolls perfectly. Did this on 2 different computers and got the same results. The screen-saver pics even look good stretched out to full-screen.  :applaud:
-HarumaN
