Author Topic: direct3d full screen "ripple" Sharp 27" SDTV  (Read 1974 times)
guko1111
  • Last login:February 15, 2012, 12:09:10 pm
« on: May 24, 2010, 06:11:31 pm »
I was wondering if anyone had a solution to an odd video problem I'm having with several emulators. When using fullscreen mode I get what can best be described as ripple effects going across the screen. I believe it's a direct 3d issue because when I use Mame and direct draw I don't have that problem, or when I use cabmame that has the cleanstretch option for d3d it doesn't "ripple".
Nvidia geforce 8200 video
Sharp 27f543 tv for monitor
isucamper
    • my project arcade blog
Re: direct3d full screen "ripple" Sharp 27" SDTV
« Reply #1 on: May 25, 2010, 08:08:34 am »
Are you talking about screen tearing?  This happens when you're games frame rate isn't locked to 60hz (the refresh of your monitor).
THE SYSTEM          Popeye
guko1111
« Reply #2 on: May 25, 2010, 02:19:24 pm »
It isn't quite screen tearing, but I was able to get it fixed. It came down to trying all kinds of different resolutions  and turning off any "ntsc" type aspect ratios in the various emulators.
