Author Topic: Instant Sheller... ARGH!!  (Read 1774 times)
badgerjohn
  • Last login:May 03, 2016, 09:42:33 am
« on: May 22, 2010, 06:41:40 am »
Can anyone help me with Instant Sheller? It's driving me CRAZY!!! :banghead:
The problem I'm having is that it is all working bar auto login. It comes up saying it couldnt log in and I have to manually hit "Return" to get past the password screen.
Has anyone else had/overcame this problem?
I'm running XP home if that helps?
bkenobi
Re: Instant Sheller... ARGH!!
« Reply #1 on: May 22, 2010, 09:46:42 am »
Tom over at the GameEx forums will support Instant Sheller since he is the author.  I don't know if he frequents this forum, so you would be better off posting there IMO.   :cheers:
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #2 on: May 22, 2010, 10:14:59 am »
Funny I was dealing with this last night. Here is the info I think you need:
Bypass The Windows XP Log On Screen
To make logon an unattended process:
Click [Start] [Run] and type
control userpasswords2
Click [OK]
The [User Accounts] Property Sheet displays.
On [Users] tab, clear the [Users must enter a user name and password to use this computer] check box.
Click [Apply].
Enter a user name and password that should be used to logon automatically in the dialog box that appears.
Click [OK].
Go to [Control Panel] [User Accounts] [Change the Way Users Log On and Off].
Uncheck [Use the Welcome Screen] and [Use Fast User Switching]
Hope it works for you!
"Some drink from the fountain of knowledge; I only gargle."
manman
  • Last login:September 17, 2020, 01:48:26 pm
« Reply #3 on: May 22, 2010, 02:44:21 pm »
yes, something like this was happening to me too- although I didn't get any message saying it couldn't log in.  Basically it logs in perfect the FIRST time I enable instantsheller, then every subsequent time it gets stuck on the boot screen...
I will try the suggestion above, thanks for the tip!
badgerjohn
« Reply #4 on: May 24, 2010, 08:49:52 am »
Thanks guys but that didnt work and was killing me!! So i did some digging around of my own, found an article on Microsoft's website to add another key to the registry and it worked a treat!!
Here's the link:
http://support.microsoft.com/kb/315231
I already had the "DefaultUserName" string in my registry, so added the "DefaultPassword" string and if i remember rightly this fixed it straight away... what a result..
Anyway, I hope this helps anyone else with the same issue...
And more importantly.... my 1st ever cab is nearly finished!!!
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
« Reply #5 on: May 24, 2010, 09:41:01 am »
Lets see some pics then!
badgerjohn
« Reply #6 on: May 24, 2010, 01:13:25 pm »
The cab is at my dads as he's got more space to build it, plus I'm off to the States for a week this Wednesday to make my fortune in Vegas so I'll have some pics taken when I get back!! Exciting times now the end is in sight!!
