Author Topic: I Pac2 Shifted Keys Mapping?  (Read 1447 times)
Flip The Switch
  • Last login:July 02, 2012, 02:33:48 am
  • I grew extra fingers for gaming....
« on: May 16, 2010, 02:49:24 am »
Does anyone know the correct way to do this? im having alot of problems, i want to be able to bring up the menu (tab key) using 2 buttons (i only have a 6 button joystick)
does anyone know the correct way to do this or know of a tutorial?
:picsMy first cab - Plutos rebuild:pics
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
Re: I Pac2 Shifted Keys Mapping?
« Reply #1 on: May 16, 2010, 10:09:46 am »
Go into the TAB settings, select GENERAL CONTROLS, then find the commands you want and hit enter once, then press the buttons you want for that command. Remember that when you change the tab key, you will have to use the new config to get out of the menu. Also, if you want to remap the ESC key, be carefull! When you remap that key, you will be forced to use the new config to close a game.
But the ipac has all these pre-configured with the "shift" key, just move the wires around to match the ipac functions...
