Author Topic: Cabinet Button Question  (Read 2498 times)
Turf
  • Last login:August 02, 2024, 02:15:59 pm
« on: May 15, 2010, 01:05:37 pm »
Are there any games out there that use more than 6 buttons?  I'm sure there are, but I'm working on my CP and I'm trying to decide how to place all my buttons.  I have 19 buttons to work with.  Right now, I'm planning 6 player buttons, coin, and start for each player = 16 buttons so far.  Then and Esc, Pause, and a Shift for Admin buttons.
Back to the original question, what games use more than those 6 buttons?  This is kind of a cost vs. reward type decision.
WhereEaglesDare
    • My HomePage
Re: Cabinet Button Question
« Reply #1 on: May 15, 2010, 02:01:55 pm »
I cant think of any.  I explored the same question not long ago.
Don
  • Last login:March 26, 2024, 04:39:03 pm
« Reply #2 on: May 15, 2010, 02:24:12 pm »
No arcade games really use more than 6 buttons. If you're playing console games then you might be happy to have an extra button but generally games that require more than 6 buttons to play dont suit arcade controls.
A lot of people but a seventh button down and to the left of the 6 buttons (assuming a street fighter layout) so that they can have the 4 bottom buttons for NEO-GEO games. Also mortal kombat 3 and 4 had the 'run' button in this position. So if you have spare buttons, enough space and dont mind a little extra button configuring in MAME you might consider using a 7 button layout.
WhereEaglesDare
    • My HomePage
« Reply #3 on: May 15, 2010, 02:59:48 pm »
how do you tell mame that the 7th button is NEOGEO's 1st button?  and still keep all the others in a 6 button configuration??
If I could figure this out then I would put in a 7th button!
Also how do you use GameEx's CPViewer to fix it so thatit tells you the panel configs for NeoGeo Games.
« Last Edit: May 15, 2010, 03:04:05 pm by WhereEaglesDare »
Don
« Reply #4 on: May 15, 2010, 03:09:27 pm »
Apart from changing the config for each game manually im not sure. You could use a different emulator for your neo-geo games, like FinalBurn Alpha, and map the controls in that to use the 4 buttons. I use this emulator as it runs neo-geo and cps2 games better than MAME on my verry old pc :). I also use the front-end AtomicFE which allows you to have games from different emulators in one screen, and so i can still have all my arcade games in the one screen. If there is no way to change all your neo-geo configurations in mame in one go you might consider that option :)
WhereEaglesDare
    • My HomePage
« Reply #5 on: May 15, 2010, 03:46:15 pm »
im gonna go with the 6 and then see how it works out i can always add a button later, its kinda harder to take one away when i decide i dont like it.
syph007
« Reply #6 on: May 15, 2010, 03:54:50 pm »
urebelscum had a solution for this, it comes up as a question here alot.
http://forum.arcadecontrols.com/index.php?topic=78362.msg817195#msg817195
WhereEaglesDare
    • My HomePage
« Reply #7 on: May 15, 2010, 04:14:06 pm »
that seems to be a pretty good answer, but i cant find mame.ini in my mame folders.  am i missing something?
Hoopz
  • Last login:Yesterday at 06:24:57 am
  • Intellivision Rocks!
« Reply #8 on: May 15, 2010, 04:23:03 pm »
If using windows, go to start, run, type "command" without the quotes, hit enter.
In the "dos" window that pops up, go to your mame directory and type "mame -cc" without the quotes.  That creates your mame.ini file.
WhereEaglesDare
    • My HomePage
« Reply #9 on: May 15, 2010, 04:33:45 pm »
Got it, I read the wiki.   :lol  Why is it that it seems like Im a complete moron when I read these things?
« Last Edit: May 15, 2010, 04:46:14 pm by WhereEaglesDare »
