Author Topic: Monitor for Williams Cabinet Convert to 1xxx in 1 (VGA, LCD, or Component TV)  (Read 1831 times)
Larrabee
  • Last login:June 01, 2011, 07:01:24 pm
Hey everyone.
I am in need of some help.
I currently have an old Williams cabinet (robotron 2049). Here are some images:
As you can see, the monitor is on it's way out and there are a TON of scratches on the tube itself (not the plexi):
I just ordered the Killer Edition Jamma Board from Tim and it only outputs to the arcade monitor or to VGA.
So my question is:
1. Do I go with a 19" LCD monitor that is 16:10 or spend almost $400 for a 20" Dell or HP 4:3
2. Or do I put in a used 21" Trinitron VGA monitor from Craigslist.
3. Or CAN I somehow convert the vga output to component (not composite or S video) and still have good quality?
Thanks in advance!
« Last Edit: May 11, 2010, 12:15:21 am by Larrabee »
Larrabee
Also, I have tried a degaussing rod with no effect. Someone recommended I demag the monitor by discharging it like this:
Here is a picture of the monitor.
Also here is the monitor I got for $25:
lilshawn
  • Last login:December 15, 2025, 02:24:06 pm
no. all your doing is getting rid of the charge in the tube that it uses to operate... you need to do something about the magnetism. google "manually degauss monitor" for a plethora of info on this subject and various was to do it.
your monitor otherwise looks great. (good color, focus is great , not dim or washed out. the screen could be turned up a tad....)
you could...but if the existing one is still good....
the question is....
the answer is:
short answer: no.
long answer: not without some expensive electronics...or allot of knowledge to build it.
Larrabee
Thanks for the info! I decided to go with the 21" Sony Trinitron. Looks awesome running my Dreamcast through VGA.
I started a thread on mounting and supporting it here:
http://forum.arcadecontrols.com/index.php?topic=102605.0
