Author Topic: Recently capped WG19K7602 blew fuse and now has no neck glow  (Read 3362 times)
midnightpulp
  • Last login:September 03, 2014, 11:48:19 pm
Hi guys. Recently capped my 19K7602 in my Jamma cab. Everything went well. Machine ran great for 3 days up until last night. Went to turn it on and got nothing. Pulled out the board and discovered the fuse was blown. Replaced the fuse, still nothing, not even a faint neck glow. Checked the B+ and it's 0. Referring the manual's troubleshooting flowchart, it says to check the filament circuit which I'm unsure how to do.
Other than that, maybe I have a shorted HOT?
Gonna pull out the board again tonight. Anything else I should look for?
Any help is greatly appreciated.
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
Re: Recently capped WG19K7602 blew fuse and now has no neck glow
« Reply #1 on: May 03, 2010, 07:11:11 pm »
any time you re-cap a board you have to check the B+, often components get strained when the voltage is low due to bad caps, then all of a sudden, the load is less, now that the caps are good, but things like resistors have changed value...your voltage probably blew out the hot.
check with a meter set to ohms and put your red on the first leg and the black on the second...it should read high resistance. if it reads open or no resistance it's bad.
SirPeale
  • Green Mountain Man
« Reply #2 on: May 03, 2010, 09:42:12 pm »
To clarify - you replaced the fuse - is the new one still good?
midnightpulp
« Reply #3 on: May 03, 2010, 10:11:57 pm »
Just pulled out the board. New fuse is indeed blown.
midnightpulp
« Reply #4 on: May 03, 2010, 10:22:23 pm »
Just checked. Got a reading of 0.01. So I assume that's open. Looks to be bad then.
Anything else I should check?
Thanks for your help.
SirPeale
« Reply #5 on: May 04, 2010, 06:14:25 pm »
That's with the Ohms setting?  That's a dead short.
midnightpulp
« Reply #6 on: May 04, 2010, 07:06:46 pm »
Yeah.
Should I check anything else? C36?
Thanks.
SirPeale
« Reply #7 on: May 04, 2010, 08:59:04 pm »
Since you have your meter out, you might as well check anything and everything.  Definitely C36, C37, C38.  C69 if yours has one.
midnightpulp
« Reply #8 on: May 04, 2010, 09:10:40 pm »
Thanks. And to clarify, I will also check those components on the Ohm setting?
Also, what's the process for replacing the HOT? I'll need heat sink grease, a mica insulator, and of course the HOT, correct? Do I use the grease to glue the insulator to the hot and then to glue that to the metal piece behind it?
Thanks again.
