Author Topic: future pinball wrapper exe wont close in mala  (Read 3535 times)
procreat8
  • Last login:July 13, 2010, 06:03:29 pm
« on: April 26, 2010, 03:04:57 am »
hi I'm quite new to this but i have been looking about the web and not really found anything i had a focus issue when loading future pinball from Mala (newest) so i installed a wrapper for it which works but when i exit the simulator future pinball table closes but Mala still has a starting screen and the wrapper splash screen still says loading and wont shut down someone must know what to do i think there must be a extra bit needed to the execution command thanks in advance
  • Last login:September 16, 2025, 12:02:04 pm
Re: future pinball wrapper exe wont close in mala
« Reply #1 on: April 26, 2010, 10:54:52 pm »
I never could get it to close properly until I installed autohotkey & mapped one of my buttons to the esc key.
http://www.autohotkey.com/
I mapped the middle mouse button (unused on my x-arcade tankstick) to esc using the following script-
MButton::escape
Create a shortcut to the script, right click to copy it, then paste it in the startup folder.
(right click start>explore all users>programs>startup)
This will launch the script with windows and a middle mouse button click with post as the ESC key.
This has fixed every emulator I had trouble exiting.
I learned just enough about autohotkey to get that done and nothing more, so I probably won't be able help you with it anymore than that.  ???
Or....
If you can tolerate it running windowed instead of fullscreen, I found that works also.
procreat8
« Reply #2 on: April 28, 2010, 12:40:24 pm »
 :applaud: thats great thanks all done  :applaud:
