Author Topic: Plywood vs MDF  (Read 21114 times)
RandomCitizenX
  • Last login:May 05, 2014, 03:26:34 pm
Plywood vs MDF
« on: April 19, 2010, 03:44:06 pm »
I am in the process of gearing up for my first cab build and I realized I don't know if I should be using MDF or Plywood. Can anyone please enlighten me over the strengths and weeknesses of each beyond the information on the wiki?
Blanka
Re: Plywood vs MDF
« Reply #1 on: April 19, 2010, 04:54:01 pm »
Plywood is stronger and lighter and no "crawl", MDF has "crawl" (it deforms permanent under a load).
MDF is great to paint or to laminate
Plywood is good to laminate, less suitable for painting
Either is fine, if you think they made the original cabs of even a crappier material than these two (chipboard).
OldTymeToys
  • Last login:July 28, 2020, 09:29:32 am
Re: Plywood vs MDF
« Reply #2 on: May 05, 2010, 03:52:28 pm »
+1.  MDF also creates A TON of dust when cutting!  Clean up is a b!tch and breathing the stuff isn't all that great either.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
Re: Plywood vs MDF
« Reply #3 on: May 06, 2010, 10:29:28 am »
Don't forget MDO plywood.  Lightness of plywood and similar paper face for easy paining.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
BurningBeard
  • Last login:September 06, 2019, 03:17:25 pm
Re: Plywood vs MDF
« Reply #4 on: May 06, 2010, 10:26:56 pm »
My vote would be for MDO, I used it on the sides of my cab and it worked out great.  It is a little more costly and sometimes hard to find.  I had to special order mine from the local Lowes.
laggerific
  • Last login:February 21, 2014, 09:40:42 pm
Re: Plywood vs MDF
« Reply #5 on: May 19, 2010, 05:05:07 pm »
I'm in the same boat right now.  The MDO is twice as expensive as the MDF, but I like the idea of it being more solid than MDF.  I've seen how bookshelves sag, and I just don't want to risk that happening to my hard built cabinet (my first wood project outside of shop class 20 years ago).  Plus, I like the idea that MDO can handle moisture better - on top of it being lighter.
Any word on if MDO is any more difficult to cut than MDF?
« Last Edit: May 19, 2010, 06:48:09 pm by laggerific »
dawolv
  • Last login:March 25, 2016, 08:23:21 am
Re: Plywood vs MDF
« Reply #6 on: May 20, 2010, 01:08:22 am »
This is also my first cab and I was in the same boat last week.
First I knew my cab will be moved around from my garage to my office then into our 'kick back room' (Kick back room is not yet completed).
So I needed less weight and high durability.
I weighed the two
MDF Downsides (for me):
Weight
Durability during moving
Splitting
The dust: MDF Dust scares the be-jesus out of me when routing or sanding etc, (resin. glues, and urea-formaldeydes.)
Gums up my tools
Downside on the Ply (for me):
Cost-about $13 more a sheet
I went with the 3/4 Birch Plywood which worked out well since my plans got modified to smaller footprint.
Blanka
Re: Plywood vs MDF
« Reply #7 on: May 20, 2010, 02:43:45 am »
Come on, don't be a sissyboy. Man has to train its protective mechanisms now and then. If MDF routing is your dayjob, be scared. For your once in a lifetime cab, shutTFup and eat some dust!
Ed_McCarron
Re: Plywood vs MDF
« Reply #8 on: May 20, 2010, 09:16:35 am »
Plus, when you blow your nose, you can use it to fill the holes left by the screwheads.
Just spend $30 on a decent respirator and you won't have any issues beyond cleanup.  You'll be finding MDF dust in things for a month.
dawolv
Re: Plywood vs MDF
« Reply #9 on: May 20, 2010, 10:08:37 am »
 :laugh2:
syph007
Re: Plywood vs MDF
« Reply #10 on: May 22, 2010, 08:58:21 am »
I used plywood for 2 reasons, the weight and the fact that MDF is nasty to work with, unless you plan on doing all the work outdoors.
milkit
  • Last login:June 28, 2014, 09:14:33 pm
Re: Plywood vs MDF
« Reply #11 on: May 23, 2010, 10:25:07 am »
yesterday, i used some nice plywood for the first time over mdf.
uh wow. its about 10000x easier. For one, the weight is SO much lighter. it makes things like cutting a big 4x8 sheet so much easier.
The cleanup was also so much better.
I got the sheets for $40 compared to $25ish for mdf. Worth the difference plus my blades/bits will last longer
CadeFreak
  • Last login:October 29, 2010, 11:48:44 am
Re: Plywood vs MDF
« Reply #12 on: May 24, 2010, 02:35:53 pm »
I use 3/4 inch ply myself. It can take weight way better and also takes a beating well!
I know it can be quite expensive like in Ireland from a retailer you can expect to pay up to and between €42-€52 per sheet.
 If you know anyone who works with ply like a builder or carpenter ask them to get you a trade price or when they are buying materials for a job which will save you a lot of cash that can be used else where and on other things for your project  ;D
D to the mofo M
laggerific
Re: Plywood vs MDF
« Reply #13 on: May 28, 2010, 02:29:34 am »
Can you route MDO?  I'm considering going with MDO for my cabinet, but I will need to route a bit for my CP.
Kirky
  • Last login:November 13, 2010, 03:03:26 pm
Re: Plywood vs MDF
« Reply #14 on: May 28, 2010, 01:45:45 pm »
For my first cabinet, I went with 3/4" MDF.  It's very easy to work with, however the weight is a bit problematic.  I think it used about 3 sheets of MDF for a full size 4 player cab.  If you can find 5/8" I'd go with that...
Not sure what I would use on another one.  I really like the finish on the the painted MDF and it's holding up quite well.  I was looking at Panolam for some kitchen cabinets I was looking at building, maybe I'll try that next time.  It was fairly expensive, at least compared to the regular malamine sheets.
jan25th
  • Last login:September 11, 2025, 10:15:20 am
  • Long time lurker
    • forum.arcadecontrols.com/index.php/topic,147244.0.html
Re: Plywood vs MDF
« Reply #15 on: May 30, 2010, 12:02:59 am »
Plywood weighs so much less than MDF that is reason enough to use it, especially when wielding a 4x8 sheet. Plus plywood can hold your screws much better than mdf.
Blanka
Re: Plywood vs MDF
« Reply #16 on: May 31, 2010, 09:22:37 am »
Screw screws! Glue is the new screw. Easier finishing also.
laggerific
Re: Plywood vs MDF
« Reply #17 on: June 01, 2010, 03:34:31 pm »
I was just calling around to get some numbers for MDO, and I was chatting with one of the sales reps and asked him what he'd recommend as an alternative to MDO as far as getting a smooth finish, in addition to the normal advantages of Plywood, and he suggested Birch or Maple plywood.  Anyone used something like that?  How well did the paint look?  Would you still recommend some sort of veneer?  Also, how well in an indoor environment would Birch or Maple hold up compared to MDO?  I understand that MDO is nearly impenetrable and good with moisture, would I have similar luck with the Birch/Maple?  I really want this to be a solid cabinet.
Blanka
Re: Plywood vs MDF
« Reply #18 on: June 01, 2010, 04:41:48 pm »
Birch has the finest grain, but it still is nowhere as smooth as MDF. Never paint it directly, unless you want grain-looks. Not to mention the problems with edges connecting 2 faces non tapered.
gwjrabbit
  • Last login:January 13, 2014, 02:43:00 pm
Re: Plywood vs MDF
« Reply #19 on: June 01, 2010, 04:48:04 pm »
I just built mine with MDO, and I can't say enough about it.  It was so great to work with.  Build gallery here:
http://www.flickr.com/photos/26363567@N07/sets/72157623907409479/
I'm not sure I buy the supreme water resistance thing, but I'm sure there are differences between types and grades.  It's certainly smooth though, and it was easy to sand wood filler flush to it.
Jouster
  • Flap, Flap...Crash
Re: Plywood vs MDF
« Reply #20 on: June 10, 2010, 07:03:35 pm »
I guess I'm going to have to check into the MDO thing...never heard of it but it sounds great.
MDF or Plywood for me is simple, I prefer MDF for all my projects...arcade cab or not.  MDF is easier to finish, unless you pay extra for sandply.  I don't generally mind the added weight of MDF.  In fact, when I created my bartop, I thought having a little extra weight would be a good thing as I didn't want an animated player to be able to shift the thing while playing.
MDF dust is no big deal, you don't need an expensive respirator either.  I bought some cheap masks...and if you get a router with a vac attachment...there isn't much dust to begin with.
Jouster
stuartfox
  • Last login:December 08, 2013, 11:49:03 am
    • Stuart Fox TV / Film Composer
Re: Plywood vs MDF
« Reply #21 on: June 15, 2010, 09:16:01 am »
Hi everyone:
I just finished my first cab made out of MDF - it was fine but I'd use ply if I was going to build another one - the dust was nasty!
Stuart
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
Re: Plywood vs MDF
« Reply #22 on: June 28, 2010, 11:21:57 am »
Yeah mdf has a lot of dust, luckily I built my cab outside so it wasn't too bad since my backyard is mostly grass and dirt.
erictrumpet
  • Last login:February 17, 2016, 11:59:23 am
Re: Plywood vs MDF
« Reply #23 on: July 04, 2010, 02:03:27 am »
Isn't everyone's yard mostly grass and dirt? What else would it be? :)
On topic: I prefer MDF. Dusty, yes, heavy, yes, splits easily, yes. All fairly significant downsides. But it is sooooo easy to finish, and the edges are even acceptable as finished surfaces when treated properly. I think of MDF as modeling clay - I can make all sorts of weird intricate shapes out of it and it always cooperates.
Eric.
katrah
  • Last login:July 06, 2010, 12:07:20 am
Re: Plywood vs MDF
« Reply #24 on: July 05, 2010, 11:51:55 pm »
I would definatly use plywood if was going to laminate it for a perfect finish.
still mdf is great for painting, sands with ease and is quite nice to work with  :)
The Lumberjackass
  • Last login:January 09, 2015, 08:58:56 pm
Re: Plywood vs MDF
« Reply #25 on: July 09, 2010, 09:09:54 pm »
either of the above materials mentioned.
both will work just as well as each other , but if you use plywood , you can use a kreg jig and
pocket hole all your joinery instead of gluing. its fast , its strong and no outer filling needs to be done as
all the screws are internal.
just dont try and pocket hole mdf in the same way , it cant take screws as good as plywood can.
mdf is king of the hill for arcade cabs though.
use melamine faced mdf and you wont have to paint anything. check my vids , i didnt have to paint any of the main cab .
http://forum.arcadecontrols.com/index.php?topic=103919.0
I may be a jackass , but im no fool !
Stars2099
  • Last login:September 26, 2010, 02:22:58 am
Re: Plywood vs MDF
« Reply #26 on: July 12, 2010, 10:36:22 am »
Hey, I'm starting my first arcade cabinet.  I want to Home Depot and tried picking up MDF, but man is that stuff heavy.  I almost threw my back out lifting it.  So, I've decided to go with MDO, since it's lighter and I can paint on it, but I can't find the thing anywhere.  I've called local lumbar stores, but none of them carry/heard of it.  Anyone know a place that carries it in the Dallas/North Texas area?
kaorutan
  • Newbie
  • Last login:July 23, 2010, 09:28:59 pm
Re: Plywood vs MDF
« Reply #27 on: July 22, 2010, 08:52:31 am »
MDF is much more stable. Unless you use good quality baltic birch ply, most plywood sold today will warp severely if not cut and assembled within a day or 2 of being puchased, provided you can find flat plywood to start with. If you seal and paint your MDF, you really shouldn't have any moisture problems.
bar counter stools available at affordable prices.
NeoFlynn
  • Last login:October 17, 2011, 02:03:31 am
  • New Vegas Here I Come...
    • Neoflynn's Randomness, Rants and Reviews
Re: Plywood vs MDF
« Reply #28 on: July 22, 2010, 06:17:24 pm »
I was about to ask this same question, I am only doing a CP and possiably a new bezel and marquee so i think the wait difference alone is enough reason for me to go with Ply but im not sure about not being able to paint it, the CP and Bezel wouldnt be a problem but maybe with the marquee we shall see i guess, and I swear when I looked at it today Ply was cheaper but I may have been mistaken
XNIF
  • Last login:January 18, 2017, 04:40:32 pm
Re: Plywood vs MDF
« Reply #29 on: August 19, 2010, 09:32:45 am »
If you are going to use laminate i think it does not matter what you use. I've used OSB....  i would not advise that. But now i know. It's fine but it chips fast and weighs a ton.  And water is the enemy, once you have water on OSB you are done for so i am using primer on it before laminating hoping this will keep water out.
Same is for MDF, water is not good for mdf. Plywood is much better resistant againt water.
  • Last login:November 29, 2025, 04:34:53 pm
Re: Plywood vs MDF
« Reply #30 on: August 19, 2010, 09:34:58 am »
I'm planning on using MDF on a full-size cab build, because I'm planning on painting my cab rather than using laminate on it.  I need to be sure the finish is perfect, as it will likely be fire-engine red, and for that, I like MDF.  You can't beat the smooth surface for taking paint, especially if you've properly prepped every nook and cranny of your build.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
Re: Plywood vs MDF
« Reply #31 on: August 19, 2010, 11:10:57 am »
MDO is awesome to work with. I'm using it on the Project Arcade 2 cabinet, and having built with both MDF and MDO now MDO is the way to go. I had to special order it though, and it's expensive, but it's got all the benefits of MDF and plywood without the drawbacks. It was straight as a board, no warping. Smooth sides. Lighter than MDF. Much less dust when cutting/routing the wood.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
XNIF
Re: Plywood vs MDF
« Reply #32 on: August 19, 2010, 01:07:06 pm »
So... the winning order:
1) MDO
2) Plywood
3) MDF
4) OSB
Blanka
Re: Plywood vs MDF
« Reply #33 on: August 19, 2010, 03:25:25 pm »
1) MDO
2) Plywood
3) MDF
4) OSB
Well, the originals all used number 5: particleboard.
The Lumberjackass
Re: Plywood vs MDF
« Reply #34 on: August 19, 2010, 04:10:56 pm »
OSB ??
really ? that is one sheet material i would never dream of putting on a list for a cab.
im not trying to prove anyone wrong here but using osb as a material for building a cab is downright silly.
osb is used for the bulding of new houses , i.e - its used primarily for sheeting over floor board's for attics
and also for panelling off large sections.
it was designed to have the same rigidity or better than plywood , but be cheaper and lighter.
they have achieved this by glueing layers of thin wood strips.
osb is not arcade cab friendly. it does not have a smooth surface ( in fact its completely rippled everywhere ) and
isnt exactly laminate friendly ( it'll attach alright , but the finish will be lumpy in parts ).
i wouldnt even trust it to hold t-moulding correctly.
gryhnd
Re: Plywood vs MDF
« Reply #35 on: August 19, 2010, 04:15:59 pm »
MDF - I still use it, and yes the dust is nasty, but the worse thing is how quickly it dulls your tools. I probably get 50% less (total out of ---my bottom---, don't quote me on it guess) usable life out of a router bit or hole cutter when used on MDF, as compared to other products. That's a 'hidden' cost I didn't count on when I did my first cab.
Completed: No Name Upright
push2reject
  • Last login:January 28, 2014, 06:55:40 pm
Re: Plywood vs MDF
« Reply #36 on: August 20, 2010, 01:03:21 am »
OSB ??
I think people say OSB when they might mean PB.  I'll be trying out melamine PB on my upcoming build. I don't see it used a lot on these forums.  Cheap and no need to paint, but it does have its downsides.
On the other side of the screen, it all looks so easy.  -Kevin Flynn
The Lumberjackass
Re: Plywood vs MDF
« Reply #37 on: August 20, 2010, 06:41:45 am »
" I think people say OSB when they might mean PB.  I'll be trying out melamine PB on my upcoming build. I don't see it used a lot on these forums.  Cheap and no need to paint, but it does have its downsides. "
somehow i dont think so :)
i really cant see how particle board can be confused with osb. but regardless , even it is was a genuine mis match of sheet material / mistake , let me say that osb should not , and never be used as a material for building a cab. all you need is 1 person to read the above list and think , " well , its listed on the best site in the world for building cabs , so it must be a good material to use " . well im saying its not and to keep away from it.
secondly, i am pleading with you not to use particle board. its dirt cheap for a reason and you'll be sorry you used it.
spend an extra 30 bucks  / euro's / pounds etc etc , on melamine faced mdf and you wont look back. im telling you as a woodworker and
also as somebody who has experience in all materials , please do not use pb. use mdf / plywood or mdo.
im sure every other cab builder here will agree with me.
check out my videos in this section, its exactly what you want to do ( not paint a cab ).
Re: Plywood vs MDF
« Reply #38 on: August 20, 2010, 06:57:23 am »
I'm with LJ here.  I bought a sheet of melamine covered particle board for a desk in my home office, and even with very sharp tools and taped edges, every edge I cut chipped out, so when I used the edging that glued on, you could still see the rough edges.  Go MDF at the very least.  You can't go wrong spending a little more for the right stuff.
XNIF
Re: Plywood vs MDF
« Reply #39 on: August 20, 2010, 11:08:05 am »
Well... i mean OSB as in Oriented Strand Board wich i use in this project:
http://forum.arcadecontrols.com/index.php?topic=103777.0
And comments about it being more light as plywood is not true. It weighs even more than MDF. But then again it's not that bad. I will fill the holdes and little cracks first then primer it, and then laminate it. yes more work but i will not take it apart anymore since it's not that bad. If the t-molding will suck i will change the sidepanels.
