Author Topic: Zener diode substution  (Read 2089 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
« on: April 16, 2010, 10:40:13 am »
Can a zener diode (7.5volt/1 watt) be replaced with a similar but not exact diode?   For instance would a 6.8volt/1w work in its place??
In theory, there is no difference between theory and practice, but in practice.....there is!!
WhereEaglesDare
    • My HomePage
Re: Zener diode substution
« Reply #1 on: April 16, 2010, 01:24:19 pm »
really depends on the application..  Usually Zener Diodes are there to protect the circuit from power distortions and feedback...  Depending on where it is in the circuit I would most likely find an exact replacement.  Try Mouser Electronics or NEC.  In fact the NEC site should have a substitution chart on site somewhere so you can get the most compatible Zener to what you had.
Ive used Mouser Electronics for years when I had my own repair shop, never any issues with them.
Also you gotta think of tolerance.  6.8volt from a 7.5 volt, that is a 10% difference and may cause a lot of unwanted effects.  Usually if a component is out of tolerance more than 5% in CRTs they need to be replaced.
« Last Edit: April 16, 2010, 01:41:05 pm by WhereEaglesDare »
