Author Topic: anyone use pcsx2 emulator yet?  (Read 2023 times)
jamesjones626
  • Last login:March 08, 2025, 01:58:57 am
« on: April 16, 2010, 02:41:27 am »
i was wondering if anyone has used it yet, i just got it and found the bios needed, i just dont have any ps2 games on me.  let me know what you guys think and if you need a powerful pc to use it
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
Re: anyone use pcsx2 emulator yet?
« Reply #1 on: April 16, 2010, 03:06:30 am »
Last time i tried it on my P4 3.0ghz it worked, but was barely playable.
Might work on a dual core machine, but i also think it depends on your graphics card.
What are your PC specs?
jamesjones626
« Reply #2 on: April 16, 2010, 05:05:45 am »
2 gigs of ram, 5000+ amd, 3400 ati
solidteezme
  • Awesome!
« Reply #3 on: April 16, 2010, 05:23:29 am »
Best to just try it then, get hold of some discs or iso's (google is your friend, but there going to be BIG files) also if you get hold of any discs you can use alcohol 42% to rip your own iso's.
Post your results would be interesting to know.
WhereEaglesDare
    • My HomePage
« Reply #4 on: April 16, 2010, 06:57:15 am »
I tried it on a P4 3.2 GHz for God of War 1 and it was barely playable, it was playing at 30 fps so all the motion and animation was at halfspeed.  It did work but you cant use it, also i tried it from a disc and an iso and the iso worked much better FYI so if you try a disc and you cant getit to play right try the iso.
ratsflif
  • Last login:January 29, 2024, 06:08:07 pm
« Reply #5 on: April 17, 2010, 12:37:22 am »
I have it setup on both my cabs.  There are some really great shmup ports that came out on PS2 and work perfect in the emulator like, Do DonPachi Dai Ou Jou and Esp Galuda.  Even the screen rotation in the games work so I can play them perfectly on my vert Blast City.  Also, Metal Slug 6 plays perfect on it.
Here is ESP Galuda:
« Last Edit: April 17, 2010, 12:43:16 am by ratsflif »
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #6 on: April 17, 2010, 01:03:45 am »
uhm... i'm running a 2.6 ghz i7 with an ati hd radeon 4850
many games work great, including a bunch of fighting games
jamesjones626
« Reply #7 on: April 17, 2010, 03:31:58 am »
im a tekken head, so im planning to buy them.  i hope they work out.
WhereEaglesDare
    • My HomePage
« Reply #8 on: April 17, 2010, 09:24:21 am »
What video plugin would you use for a singlecore P4... if I remember right the was the emulator works it uses your CPU more for graphic processing than the graphics card...  this may be why i cant get it to run at 60 fps
