Author Topic: Bug in Layout Editor  (Read 2196 times)
raungst
  • Last login:October 14, 2016, 03:05:40 pm
« on: April 15, 2010, 12:30:39 am »
I seem to have found a bug in the layout editor. Whenever I try to set a picture as the exit window, it ignores it when I try it in Mala. Whenever I set the lowres mode of the exit window, as soon as I close the exit window in the editor, it immeadiately reverts back. Even when I try to just set the background color, it doesn't seem to take all of the time. Is there any workaround for this? I'm using Mala 162g, and they layout editor says version 1.5.
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Bug in Layout Editor
« Reply #1 on: April 15, 2010, 02:39:54 am »
Hi,
It seems to work for me.
Do you have the image in the right place? (I subfolder or mala directory depending on the layout options settings in mala)
If so can you go through what process you go through step by step so I can try and recreate the issue?
raungst
« Reply #2 on: April 15, 2010, 09:11:35 am »
Hmm... I'm guessing that's my issue. At least with the picture. I think I have it in the root folder for all of individual layouts, and not in each of the folders for each layout. Does the lowres option stick for you?
loadman
  • Moderator
    • MaLa
« Reply #3 on: April 16, 2010, 01:16:19 am »
Just checked it and it works for me
