Author Topic: How should I install side art?  (Read 1736 times)
kingfish
  • Last login:July 23, 2010, 04:09:39 pm
« on: April 09, 2010, 05:08:04 pm »
 I just received a pair of side art stickers for a galaxian game, but they came on rectangular sheets, not shaped like the actual art.  I guess I have to cut them out really carefully.  Is there a good way to do this?
  • Last login:Yesterday at 10:44:52 am
Re: How should I install side art?
« Reply #1 on: April 09, 2010, 05:24:54 pm »
Very carefully.  Check it out.
  • Last login:September 13, 2025, 11:24:38 am
« Reply #2 on: April 09, 2010, 05:43:33 pm »
 I would be tempted to use a real nice pair of scissors, but I know a hobby knife works too. To apply it, check out the directions javery posted. I did something real similar but I clamped a level to the cabinet instead of drawing or putting tape on it. Worked well.
MaximRecoil
« Reply #3 on: April 10, 2010, 10:19:08 pm »
I believe that Galaxian sideart is supposed to cover the entire sides of the cabinet in the same way that Centipede or Missile Command sideart does. If so; you don't want to cut the actual art shape out of the white background. You are supposed to apply the whole rectangular sheet and then trim it around the edge of your cabinet with a razor blade.
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #4 on: April 11, 2010, 09:22:55 am »
+1
Working: Not Enough
Projects: Too Many
Progress: None
