Author Topic: Mala questions  (Read 1794 times)
IG-88
Mala questions
« on: April 08, 2010, 02:27:14 pm »
1. Is there a way to add a "number times game played" counter to an existing layout? There are several layouts that I like and want to add this feature too them.
2. If you have multiple emus under Mala, is there a "one button press" to switch between each emu instead of having too right click with the mouse and then choosing "Select Emulator" from the pop-up menu?
-HarumaN
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
Re: Mala questions
« Reply #1 on: April 08, 2010, 03:01:04 pm »
First, MALA has its own dedicated forum, so you'd have better luck posting there.
1) I am fairly sure Mala has this feature, go into the Layout Editor, and you can add/remove objects with the toolbar at the top. Find a spot that makes sense and drop it there.
2) In Mala options, you can bind keys/button presses to do what you ask. I think by default its setup to switch emulators by hitting Left or Right on the joystick.
IG-88
Re: Mala questions
« Reply #2 on: April 08, 2010, 03:41:43 pm »
Thanks for the quick reply. I checked the layout editor but didn't see an option to add the counter.
As for the other, that doesn't work either. Left or right doesn't do anything. Is there a config setting somewhere for that?
-HarumaN
Neverending Project
    • Arcade Fixer
Re: Mala questions
« Reply #3 on: April 08, 2010, 04:51:16 pm »
If you're using a microswitch joystick, you'll find the settings here:
Click in "Prev Emulator" and push left on your joystick, then click in "Next Emulator" and push right.
If you are using an analog joystick, you will need to click on the "Joystick" tab, and then select the Left and Right from the corresponding pop-up menus. Make sure the joystick is enabled, too.
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
Re: Mala questions
« Reply #4 on: April 08, 2010, 05:12:33 pm »
Hi there.
In the MalaLayoutEditor, add a text with the "game played" attribute (se attachment).
Cheers, :cheers:
Congui
« Last Edit: April 08, 2010, 05:14:12 pm by Congui »
IG-88
Re: Mala questions
« Reply #5 on: April 08, 2010, 05:31:53 pm »
That did it!  Thank you very much!!   :cheers:  (all of you  :) )
-HarumaN
IG-88
Re: Mala questions
« Reply #6 on: April 08, 2010, 07:11:25 pm »
Got another small question\issue. My NES emu (nestopia) requires alt+x to exit. Is there a command line string to get this to work with mala's esc button press? Or perhaps another way?
-HarumaN
