Author Topic: How to change XP resolution?  (Read 1075 times)
JoeB
  • Last login:December 04, 2025, 08:49:00 am
  • NES Fanatic
« on: July 29, 2003, 12:01:42 pm »
Is there any other tool (outside of anything that sits on the taskbar) to change the resolution of Windows to non-standard resoltions for the ArcadeVGA???
The problem with my WindowsXP install is that somehow the taskbar got corrupt, and shows no icons (known XP flaw).
Thanks.
AlanS17
    • AlanS17
Re:How to change XP resolution?
« Reply #1 on: July 29, 2003, 12:08:09 pm »
Powerstrip has a quick taskbar component, but I'm pretty sure you can access it from the Start menu, too. I've never used it with an ArcadeVGA, but it's a very good program. I would venture to guess it would do the job for you.
http://www.entechtaiwan.com
TalkingOctopus
    • My Arcade
« Reply #2 on: July 29, 2003, 03:36:30 pm »
You can also check the Display Properties > Advanced > Adapter > List All Modes to get some additional Windows XP resolutions.
I used this menu to set it to 640 x 480 for my T.V. and ATI 7500.
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« Reply #3 on: July 29, 2003, 05:58:53 pm »
if you just need to get 640x480 then also check out a program called TV Tool.
