Author Topic: Thickness marquee plexi?  (Read 1597 times)
MB
  • Last login:June 17, 2011, 08:25:03 am
« on: April 07, 2010, 05:24:56 am »
Just a quick question. How thick should the sheets of plexiglass be that the marquee print
gets sandwiched in between? Marquee size is 18cm x 63cm (7inch x 24inch).
MB
Re: Thickness marquee plexi?
« Reply #1 on: April 09, 2010, 02:25:11 am »
Would 2 times 1mm work?
Guess they're standing straight up and won't be flexing much,
unless you push them.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #2 on: April 09, 2010, 03:54:38 am »
i take 2x2 mm plexi for that and add 2 mm for the groove so the plexi doesnt fit in 2 snug.
« Last Edit: April 09, 2010, 04:00:25 am by apfelanni »
MB
« Reply #3 on: April 09, 2010, 05:35:46 pm »
2mm it is then! Sounds better. 1mm seems a bit thin on second thought.
Thanks for your input. :)
