Author Topic: 4 - Player Arcade using 2 x Mini Ipac  (Read 2255 times)
viper221w
  • Last login:May 03, 2010, 01:16:09 pm
« on: April 06, 2010, 08:44:15 am »
Hi All,
I am in the process of building my first ever arcade system, my arcade is a 4 - player system and uses two mini-ipac's for the wiring of the controls.
I am currently at the stage now where I am using Winipac and have a slight problem, I have designed my 4 - player control panel in WinIpac but don't see the Player 3 & Player 4 connections illuminated in the ipac connection tab. This means I currently only get player 1 & 2.
Is there a trick to get two mini-ipacs configured, I wish to change some of the control mappings on the two mini-ipacs so it will work more smoothly with my emulators.
Any help is greatly appreciated.
Cheers,
Paul
  • Last login:December 02, 2025, 03:23:14 pm
Re: 4 - Player Arcade using 2 x Mini Ipac
« Reply #1 on: April 06, 2010, 02:22:00 pm »
You need a 4 player Ipac (Ipac-4) to use the software that way...
You have two mini Ipacs...  both of which have a player 1 & player 2.
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
« Reply #2 on: April 06, 2010, 09:42:36 pm »
Yeah, I don't think the software is going to work in that config.  I've got two minipacs on my four player panel too.  I program each one at a time but I don't use the WinIPAC software.  I'm pretty sure the guy who runs Turnarcades uses two minipacs in has 4 player panels.  Maybe see how he programs them?
mphuie
  • Last login:June 04, 2010, 03:44:59 am
« Reply #3 on: April 09, 2010, 06:02:20 am »
It looks like you can reprogram the keys.  Why not plug your 2nd one in then remap the keys to the MAME 3rd and 4th player config?   I don't think it matters if the config software correctly detects which one is which.  Just config them each separately.
