Author Topic: question about weight of mdf  (Read 1498 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: April 04, 2010, 07:27:38 pm »
how much does a sheet of mdf weigh? i'm not looking for any specific size, I just want to get an idea of how much it weight in comparison to plywood
crashwg
Re: question about weight of mdf
« Reply #1 on: April 04, 2010, 07:49:07 pm »
3/4" Ply ~75lb
3/4" MDF ~ 100lb
Here's a thread about the weights of different thicknesses of MDF in which I detail how determine the weigh of MDF in reply #6:
http://forum.arcadecontrols.com/index.php?topic=31918.0
And a rule of thumb for plywood is 25lb per quarter inch of thickness @ 4x8.
« Last Edit: April 04, 2010, 07:52:39 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
SammyWI
« Reply #2 on: April 04, 2010, 08:02:15 pm »
From what I've seen online:
MDF = approx 48 lbs/ cu ft
Plywood = approx 36 lbs / cu ft
Those numbers will vary some but they line up well with crashwg's numbers and with how they feel when you pick up one of each.
shateredsoul
« Reply #3 on: April 04, 2010, 08:45:21 pm »
Ahh.. so my friend was right about a sheet of mdf weighing about 100lbs..
I was thinking of going with mdf because it looks nicer when painted and it saves on cost.. but if I use two sheet we're talking about 50lbs more, hmm that's not too bad.
Sectorseven
  • Last login:November 09, 2017, 02:34:50 pm
« Reply #4 on: April 05, 2010, 01:37:26 am »
Heh, I remember working my first day at a construction job where I had to move about a hundred of those MDF boards down a flight of stairs. I was trying to show off to the older guys by bringing like 3 down at a time. They practically had to carry me out at lunch break  :-[
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #5 on: April 05, 2010, 08:57:31 am »
For my cab I used a combination of ply and mdf - the cab body is ply to save on weight and all the removable parts (control panel, doors, keyboard shelf) are made of mdf.
Robots will kill you.
Arcade Addiction
Blanka
« Reply #6 on: April 05, 2010, 09:09:17 am »
800kg/m3 if you like metric :)
daywane
  • Last login:August 29, 2025, 03:53:34 pm
  • GRRRR!
« Reply #7 on: April 06, 2010, 04:34:58 pm »
the heaviest 100lbs you will ever grab.
took me by surprise the first time I lifted a sheet and put it on my head.
