Author Topic: advancemame and ac97 sound  (Read 4245 times)
ushkar
  • Last login:November 27, 2010, 11:42:54 am
« on: March 31, 2010, 04:43:25 pm »
hi,
is there anyone who uses an onboard ac97 soundchip with advancemame in dos succesfully?
i have an intel motherboard with an AC97 chipset (82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller)
in my BIOS i have only the option enable/disable
if i change the setting in my advmame.rc to "vsync/ac97" it starts my games but...no sound.
when i run nssi.exe (diagnostic tool) it sees my ac97 chipset, but don't show any values for port, channel, irq,...
when i run advs.exe with a random wav file it gives an error (failed to initialize...)
i thought advmame supported ac97 automatically, but i think i miss something. do i have to load drivers or something?
getting a bit desperate with this...
I/O
  • Last login:June 06, 2011, 01:33:10 am
Re: advancemame and ac97 sound
« Reply #1 on: April 01, 2010, 02:49:31 am »
Try the allegro and seal drivers.
ushkar
« Reply #2 on: April 01, 2010, 03:03:50 am »
you mean the ones imbedded in advancemame? or external ones?
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
« Reply #3 on: April 04, 2010, 01:04:02 pm »
unfortunately, ac97 support is limited in advmame. there are four types of ac97 chips that i know of and i have been successful with via, sis and amd ac97 implementations. intel ich soundchip came out after the sound routine matured in vsyncmame (.60s), subsequently getting absorbed into and got stuck in the later versions of advmame.
I/O
« Reply #4 on: April 04, 2010, 10:54:41 pm »
Read the docs. That is how I found out about them.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #5 on: April 05, 2010, 12:38:10 am »
You could spend all day reading the docs for advancemame and it won't get you anywhere, especially when it comes to video and sound card drivers.  So much of the information isn't 100% accurate.
What you need is the dos drivers for the ac97 soundchip.  I used to have them but I have no idea if I still have them on disk somewhere but I do remember that it took a little searching to find them.
Also, there is an old post on these forums that had info on ac97 and dos.  I don't know if a search would turn up anything but it's worth a shot.
tikbalang
« Reply #6 on: April 05, 2010, 05:16:11 am »
DOS support for the ac97 soundchip was only released by VIA. it emulates a soundblaster pro BUT this was dropped in the later chips. the good news for advmame is it can still use these late chips with "vsync/ac97".
my recommendation for OP is to disable the onboard sound and use an old ESS pci card (esstech.com). these cards are easy to configure and if it fails, then most likely other pci audio cards will fail too. this is because of the complex irq, dma sharing, ddma, tdma issues regarding pci features and plain DOS.
