Author Topic: Can't access BYOAC forum at home.  (Read 1770 times)
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
« on: March 30, 2010, 02:53:24 am »
As title explains, im on aol in the uk and recently have been unable to go onto any of the byoac sites (wiki, forum etc) :hissy: i read somewere else about the same problem but no imformation was given. so im just seeing if anyone knows anything? I have a project im itching to post but can't!! ???
Solid,
Franco B
Re: Can't access BYOAC forum at home.
« Reply #1 on: March 30, 2010, 03:53:15 am »
I'm also in the UK and I have the same problem when trying to access byoac through aol when I'm visiting the GFs family.
I did manage to get onto byoac by using a proxy server. Probably not ideal but it worked for the access I need.
solidteezme
  • Awesome!
« Reply #2 on: March 30, 2010, 04:50:27 am »
Ill have to try that then, ent going to be ideal tho. bet it takes hours to post thru one of those. :banghead:
Solid,
« Reply #3 on: March 30, 2010, 08:22:24 am »
Ill have to try that then, ent going to be ideal tho. bet it takes an extra few seconds to post thru one of those. :banghead:
Solid,
fixt.
Franco B
« Reply #4 on: March 30, 2010, 08:27:35 am »
Ya. It's the only time I have used a proxy to be honest and I can't really say I noticed much difference.
solidteezme
  • Awesome!
Re: Can\'t access BYOAC forum at home.
« Reply #5 on: March 30, 2010, 01:29:05 pm »
Works for text, but not for posting pictures. just times out.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:September 11, 2025, 05:46:17 pm
« Reply #6 on: March 30, 2010, 01:59:21 pm »
It's likely a DNS issue of some weird kind.
Try this -- drop to a command prompt, and ping forum.arcadecontrols.com. If it returns an IP address then we can verify it's the right IP address. If it has no IP address then that's a problem too.
It should resolve to 74.208.166.36 ... If it doesn't, you can put this entry in your C:\windows\system32\drivers\etc\hosts file (note - not hosts.sam or hosts.txt, just "hosts") which should fix it. I helped another person using AOL UK with this issue and this was the resolution.
The entry:
74.208.166.36    arcadecontrols.com forum.arcadecontrols.com wiki.arcadecontrols.com files.arcadecontrols.com byoac.com
save the file then try again.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
« Reply #7 on: March 30, 2010, 03:10:33 pm »
or try open DNS
solidteezme
  • Awesome!
« Reply #8 on: April 01, 2010, 03:41:04 am »
Ill try your suggestions when i get home, cheers guys. ;)
Solid,
