Author Topic: Change desktop resolution to same size, not returning to right resolution.  (Read 1826 times)
mud409
  • Last login:June 11, 2012, 12:42:31 pm
I'm using mala to change my desktop resolution to fit the layout at 640x480. However, when I exit mala, it returns my desktop (supposedly) to 1280x720, but my TV says unsupported (I think it might be returning it to 16 or 8 bit, which my tv doesn't support for some reason). I have to manually go into the system's display properties and set it to the resolution. The thing is, Mala used to return my desktop to the appropriate resolution which my TV supported.
Is there a place to set the return resolution on mala exit?
