Author Topic: W G moniter  (Read 1974 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
W G moniter
« on: March 25, 2010, 12:14:21 pm »
I have a 19 inch WG monitor, model 19K7901, which cuts in and out every few seconds (high voltage).  HOT tests good when I had it out. Also has a slight horizontal tear at top of screen which cannot be removed by adjustment and which 'jitters' during game play. Can anyone suggest likely causes for these symptoms?
In theory, there is no difference between theory and practice, but in practice.....there is!!
grantspain
Re: W G moniter
« Reply #1 on: March 25, 2010, 12:28:59 pm »
does the 50/60hz pot not sort out the tear
as for cutting out that sounds like a bad solder joint on the flyback
kardenm
Re: W G moniter
« Reply #2 on: March 25, 2010, 12:42:59 pm »
50/60hz pot will not completley remove the tear. I did redo many solder joints including all flyback joints. picture now stays on. THANKS!!
grantspain
Re: W G moniter
« Reply #3 on: March 25, 2010, 01:08:27 pm »
ok horizontal hold and position as well
Kevin Mullins
    • Me on Myspace
Re: W G moniter
« Reply #4 on: March 25, 2010, 03:04:59 pm »
The tear can be a combination of adjustments including Contrast.
kardenm
Re: W G moniter
« Reply #5 on: March 25, 2010, 10:50:18 pm »
I'll try more combinations of adjustments.  Really appreciate all the advice!
kardenm
Re: W G moniter
« Reply #6 on: April 09, 2010, 09:55:12 am »
Got all fixed and adjusted. Very good picture now except still have horz tear on top one inch of screen BUT only happens with certain game board. Works fine with Skill Cherry but horz tear appears when I put in Crazy Bugs which seems to be a more "intense?" game (brighter, more vibrant colors).
SirPeale
  • Green Mountain Man
Re: W G moniter
« Reply #7 on: April 12, 2010, 12:35:06 pm »
Different games have different frequency settings.  When you change them out it is normal to have to make adjustments.
