Author Topic: Ugghhh My trackball broke! help?  (Read 2720 times)
said7
  • Last login:January 24, 2012, 02:24:47 pm
  • "I smell..... NERDS" - Ogar
    • www.said7.com
« on: July 28, 2003, 08:48:37 am »
I got a Imperial/Wico 3 inch Trackball. Hooked it up to the mouse port just fine and it worked like a champ on golden tee.
Couple days later I unplugged it with the computer off and went to go test fit it on my CP. When I plugged it back in it doesnt work. I have no idea what happened. I opened her up and checked the rollers and all the wire connections and all seems to be fine. I plugged into another computer to see if it was the computer still didnt work.
How can i fix it?
This really sucks cause I am so close to finishing my cab  :'(. Any suggestions?
Can i replace the electronics without replacing the whole trackball?
Would putting it next to anything magnetic have broken it?
Check out my site: http://www.said7.com
Arcade site comming soon.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
Re:Ugghhh My trackball broke! help?
« Reply #1 on: July 28, 2003, 09:07:55 am »
Magnetic fields should not have hurt it.
Is this one of the PS/2 versions that they sell?
American Laser Games Wrapper
O2em Rom Utility
said7
    • www.said7.com
« Reply #2 on: July 28, 2003, 09:13:31 am »
I bought it from someone on the board and it is the PS2 version.
dhansen
  • Last login:July 09, 2025, 05:07:33 pm
  • No Quarters Needed
    • Arcade Stupidity
« Reply #3 on: July 28, 2003, 09:20:13 am »
Check your pins on the connector, are they bent?
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
said7
    • www.said7.com
« Reply #4 on: July 28, 2003, 11:02:06 am »
Pins and connectors are all fine. I unplugged em and reglugged them to make sure.
SirPeale
  • Green Mountain Man
« Reply #5 on: July 28, 2003, 11:40:22 am »
Mouse drivers?  broken solder joint?
SirPoonga
  • Puck'em Up
  • Last login:July 20, 2025, 03:37:24 pm
  • The Bears Still Suck!
« Reply #6 on: July 28, 2003, 11:55:21 am »
First, the imperial is made by betson, not wico:)
Is it a mouse hack or the ps/2 imperial?
err, you said ps/2 version.  Meaning it came like that?
« Last Edit: July 28, 2003, 11:56:07 am by SirPoonga »
said7
    • www.said7.com
« Reply #7 on: July 28, 2003, 12:09:23 pm »
Yeah, sorry Poonga.
Its an Imperial I get confused.
It isn't a hack the PS/2 goes directly.
Chris
    • Chris's MAME Cabinet
« Reply #8 on: July 28, 2003, 02:33:47 pm »
If you got it direct from them, time to check your warranty options!
--Chris
AlanS17
    • AlanS17
« Reply #9 on: July 28, 2003, 02:41:58 pm »
Does it work when you plug it back into the original machine that it was working on when you tested it? Maybe it's the port. Try plugging it into a different PC. Try plugging a different mouse into your cabinet's PC.
said7
    • www.said7.com
« Reply #10 on: July 28, 2003, 03:14:51 pm »
I would take it back but I bought it from a fellow BYOCer.
It doesn't work on the origional machine or the machine I have upstairs.  I guess ill try bringing it to work but I doubt its the port.
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
« Reply #11 on: July 28, 2003, 03:17:38 pm »
Did you buy it from me? If so I apologise but it was only a couple of months old when I bought sold it and it sounds like it worked when you got it. I hate to see one of my sales go south, maybe we can work out something amiable, PM me.
« Last Edit: July 28, 2003, 04:49:07 pm by Birdtales »
Coming Soon
Chris
« Reply #12 on: July 28, 2003, 03:30:13 pm »
Silly question: Are you connecting the trackball with the power off?  PS/2 trackballs are not hot-pluggable...
--Chris
said7
    • www.said7.com
« Reply #13 on: July 28, 2003, 03:42:28 pm »
Yeah i am aware of this  ;D I plugged it in with computer off.
nighthawk2099
  • Last login:June 10, 2015, 04:01:16 pm
  • I LIKE TATER-TOTS!
    • IRONMAME
« Reply #14 on: July 28, 2003, 03:55:30 pm »
I might suggest using a multi-meter and checking the continuity<SP>  between the pins on the connector and the wires at the TB.  Maybe something broke between the 2 ends...
« Last Edit: July 28, 2003, 03:55:58 pm by nighthawk2099 »
Birdtales
    • Birdtales
« Reply #15 on: July 28, 2003, 04:36:54 pm »
As I said in the PM Sorry this happened. Send it back and I will refund your money.
Coming Soon
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #16 on: July 29, 2003, 01:02:16 am »
That's a classy move Birdtales.  Cheers to you!
-Ace-
I want my own arcade controls!
said7
    • www.said7.com
« Reply #17 on: July 29, 2003, 09:24:57 am »
Well i opened it up last night and double checked all the things mentioned in this thread.
I even brought it to work today and tried it out on another computer... no luck.
Now assuming the electronics is at fault if i bought the following...
Imperial & Wico TB optic pcb
from Bob Roberts would that replace all the boards in the trackball or is that just for the sensors.
Birdtales
    • Birdtales
« Reply #18 on: July 29, 2003, 09:27:02 am »
I'm sure that's just the optical sensors. What has probably gone bad is the PS2 interface part.  :(
Edit: and no I'm sorry I don't know where to get one. If you send it back I'll probably just mouse hack it.
« Last Edit: July 29, 2003, 09:28:14 am by Birdtales »
Coming Soon
Chris
« Reply #19 on: July 29, 2003, 09:48:01 am »
While you have it open, do you see any broken or loose solder joints?
--Chris
said7
    • www.said7.com
« Reply #20 on: July 29, 2003, 09:49:53 am »
Nope all solder points looked fine. And i have decent experience soldering.
I went ahead and ordered a new trackball from Happs. I will send you back yours as soon as i find a box.
I hope you can fix it. Thanks again.
ErikRuud
« Reply #21 on: July 29, 2003, 10:00:53 am »
Said7 and Birdtales,
I ordered two of those ps/2 trackballs from Betson.
Due to some confusion with the order I happen to have the phone number of the Betson facility that assembles these in Roselle, Il.
I am in another building right now, but I could send the number to you when I go back to my office at lunch time.  If you called them you maybe able to get a new board.
O2em Rom Utility
Birdtales
    • Birdtales
« Reply #22 on: July 29, 2003, 10:16:16 am »
ErikRuud - Sure that would be great, you can PM or email it to me if you don't want to post it here.
Said7 - good luck with the HAPP ball! I'll be looking for the old one. When I get it I'll PayPal ya back. Again sorry for the problems.
Coming Soon
ErikRuud
« Reply #23 on: July 29, 2003, 10:40:11 am »
I'll PM you at lunch time.
O2em Rom Utility
